Results 1 to 9 of 9
    Dec 2012
    Northants
    217
    Odd stereo problem
    Just been trying to fit my Sony head unit and came across this strange problem...
    swapped the red/yellow wires over and the Sony unit will accapt/eject cd but the stereo itself dosnt light up or play????
    I know the stereos fine as I've just took it out my golf.... Confused!!
    If it's got tits or gears it's gonna be expensive.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Unless you've fitted a wiring adapter that includes a CAN bus adapter you won't have any switched igniton feed or lights on wire - the OE Audi radios only have a permanent feed and get all the other information they need off of the Infotainment CAN bus.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Dec 2012
    Northants
    217
    ahh right so where can I buy one?
    Oct 2009
    Hull
    1,440
    just wire in a switched live
    all you need to do is find a switched live which you can take from the fuse box somewhere or there is a really thin red wire that runs under the steering column to the ignition you can wire this to a relay and power through the relay to the stereo you cant wire the thin wire direct as its too thin to carry the load, doing it this way will make it work like OE keeping the stereo on until you pull the key out
    Dec 2012
    Northants
    217
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by Dogtown22 View Post
    Any decent car audio shop.
    Dec 2012
    Northants
    217
    Just looking at the patch leads, would I need the half amplified lead??? Later on in life I want to fit a sub and amp thet I've got.
    Dec 2012
    Northants
    217
    Where can I buy a can bus stereo adapter on line?????? Cant fond one anywhere....
    Oct 2009
    Hull
    1,440
    havent got a clue and I'm pretty sure even if you do get one you still need a switched live
  1. Stereo problem
    By milie in forum In-Car Entertainment
    Last Post: 1st March 2006, 23:02
  2. Weird Stereo Problem
    By MartinM in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th February 2006, 09:28
  3. stereo problem
    By Indian in forum In-Car Entertainment
    Last Post: 11th October 2005, 20:04
  4. Stereo problem
    By Indian in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 22:33
  5. Concert stereo Problem
    By Dylarolla in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 17:45
