JMB RetrofitsEM Tuning
Results 1 to 8 of 8
Thread: Fault codes
    Dec 2012
    73
    Fault codes
    Hi guys had my a4 avant fault coded today by a very helpful member of forum couple of codes come up gearbox hydraulic pressure sensor g193 i think and also g201 brake pressure sensor which would be why my esp and abs light come on every know and then can anyone help with these codes
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Have you still got the fault codes and entered them into the Rosstech wiki? Failing that, just googling a fault code will often bring up some help.
    Dec 2012
    73
    Entered them in but couldnt find code 193 so stoll not sure wat this code means
    Dec 2012
    73
    Help
    kite's Avatar
    Oct 2007
    East Berks
    675
    Re: Fault codes
    G193 is a sensor number not a fault code.
    A4 (b6) 2.5 TDi QS Saloon.
    Dec 2012
    73
    Ok that was all i got so i need to do it again to get code then
    Mar 2008
    Dorset
    13,856
    You need to find out what the actual fault codes are, typically a 5 digit code.
    Dec 2012
    73
    Ok mate cheers will have to get it done again
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
