AH FabricationsJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
  1. #41
    glenandem's Avatar
    Sep 2012
    manchester
    528
    I've blacked my egr with plates but not disconnected the top pipe, should I disconnect that too or will it be ok?
  3. #42
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    It will be fine the top pipe only sucks the plunger open and with your plate there nothing will happen
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
  4. #43
    Nov 2012
    Quote Originally Posted by Ollie-B View Post
    Use your standard egr valve with 2 blanking plates and the top pipe disconected and then you still have your anti shudder valve for a smooth shut down. Pointless spending 50 quid when you can spend 5 or nothing if you make your own plates
    Well i have problem, till engine is cold car is very smoky,stinky and does horible 20mpg on 1.9tdi engine, once it warmed up,no smoke at all and mpg goes up to 45 as it supposed to be, so what is up with my EGR? is it stuck open or closed? what do i need to do, to stop it smoke badly at cold engine? please help,that bad smoke and terrible mpg kills my love to my Audi
  5. #44
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Either the plunger is leaking and letting ya exhaust gasses through too early or the vlave that controlls it is nackered and its stuck open. Ya can tell if its stuck open if ya unplug the top pipe and it gets better its stuck open if ya unplug it and it stays the same the plunger is leaking. Either way fitting plates instead of your pipe will sort it
  6. #45
    Nov 2012
    Thanx for reply Ollie, right where to get those plates from(cause i won't make my own) and where exactly do i need to fit them? cause i don't really understand much about engines
  7. #46
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Ebay, search audi a4 egr plates and they will be there somewere, cant miss them. And there is a metal pipe frok ya egr to exhaust manifold. Either end of that. Easyest way to test first is just pull the pipe from the top of ya egr (can do it without removing engine cover) and see how that goes. Stick a bolt or something in the pipe you pull off asael to keep ya vaccum strong or if ya valves nackerd it will constanlty suck air
  8. #47
    Nov 2012
    Thanks, why do i need to block either ends of it? not just one? i have b6, so 1end in a bottom of egr valve and another one is closer to offside headlamp? if i block them? what happens next? do i need disconnect anythiing?
  9. #48
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Yea both ends or either your egr will suck air or you exhaust willblow. Totaly remove the pipe for ya egr to exhaust manifold and fit one plate to underside of egr and one to exhaust manifold. You wont need any pipes disconnecting then as the plunger wont do anything
  10. #49
    Nov 2012
    Thank you, i think i got you this time. English isn't my native language and goole translator just sux wi9ll block that on weekend and let u know asap
  11. #50
    Jul 2007
    London
    3,234
    Quote Originally Posted by DeNi View Post
    About time ! That was supposed to be my thread...
    Anyway, the gearbox has decided to trow the toys out of the pram, it's locked in first so with the nice hot weather i will proceed with fixing it ! I will keep you posted...
    FOR SALE:
  12. #51
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    excellent thread.
    I really wish I had your knowledge of these cars (and that you lived closer to me so I could pick your brain in person)
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
  13. #52
    Nov 2012
    Ordered them, Just before i do it, will i get error light on my dash?
  14. #53
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Depends in the year mines 2001 and i didnt but others do. Thinks its late 02 the started monitoring the egr. But still some people dont get the error
  15. #54
    Nov 2012
    right. so mine is 2003(11month) so most likely will,(don't want that) if it will come on and i just take them out and put all as it was, will error dissapear or i'll need garage's help to erase that for me? Sorry for being pesky, just want to secure my self.
  16. #55
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    If it logs an error it will need erasing
  17. #56
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    636
    Any more update mate?
    So interesting how you do things mate. I rate you!
    Keep it all up!
  1. Audi a4 1.9 TDI avant 110 Bhp £800
    By adamss24 in forum For Sale/Wanted - Audi Cars
    Last Post: 30th March 2012, 03:29
  2. B6 A4 1.9 TDI Avant - MPG for Quattro vs Non-Quattro?
    By Addie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2011, 22:03
  3. audi a4 2.5 tdi avant sline b6 b7 facelift
    By the jammy one in forum For Sale/Wanted - Audi Cars
    Last Post: 14th May 2011, 23:33
  4. tell me about and thoughts on B7 3.0 Tdi Avant Auto Tip Quattro ?
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd May 2011, 21:44
  5. 1.9 tdi 130bhp fwd vs quattro mpg
    By p1tse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2011, 09:53
