Volks AutosEM Tuning
Results 1 to 7 of 7
    Dec 2012
    Northants
    217
    One rear wheel sticking out further than the other.
    Thought this deserved a thread of its own...
    Just had my car lowered and had the tracking done and wheels aligned, also fitted 15mm spacers.
    I had a garage do all the work (the garage has a very good rep too)
    When I got the car home I had a good look round it and suddenly noticed that the top of the passenger side rear wheel sits dead flush with the arch and the drivers side rear wheel (top of rim) sits about 20mm inside the arch.
    Got to take it back to the garage on monday so they can check it out.
    Any ideas guys?
    If it's got tits or gears it's gonna be expensive.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    wow that's a massive difference, i had a similar thing when i spaced mine but it turned out to be because i have 3 copy RS6 alloys and 1 genuine and the genuine had a difference off set making it sit in 8mm further,
    But 20mm seems like you have a big issue somewhere
    Andie0's Avatar
    Aug 2012
    487
    Can you post a pic up of the wheel alignment report?
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Dec 2012
    Northants
    217
    I havnt got it Andy, like an idiot I left it at the garage... DOH.
    Andie0's Avatar
    Aug 2012
    487
    Check the report could be a slight difference in cambers you cant always tell by eye! Mine is the same check out the pics i put on today of my rears! Arpund a 10mm differenc for me but im sure its just the camber needs adjsting to suit
    the thread is dgr coilys shouldnt be too far down list
    Dec 2012
    Northants
    217
    Yep I see it mate. I havnt got any rubbing issues, just want them looking the same ha
    Andie0's Avatar
    Aug 2012
    487
    Ive sorted the rubbing issues now just had to camber top in but i done bit too much on left hand side! Also had to stiffen the shocks so didnt bounce as much and is fine, am gna adjust camber on that wheel tommorow and get even both sides!
    My mates golf is like yours though had it at a garage and they found nothing wrong was just slightly not central!
    check the camber on the report then go from there, ive seen it before where someone had taken there car to a garage and this particular garage was a good place but they didnt have the correct alignment equipment because it was low and they just done it by eye and took the money! Also measure the distance from floor to fender lip and make sure its identical both sides
  1. Is there a better phone out there than the Iphone 4S?
    By StateOfPlay in forum General Chat
    Last Post: 21st November 2011, 23:04
  2. Wheel bearing noise turned out to be the bloody rear diff, please help
    By Major Lucky in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2011, 20:33
  3. any one know how to get the rear quarter window out?
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2010, 09:29
  4. Any one gone further than Stage 1 on the latest 170 TDI
    By Japtastic in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2010, 17:46
  5. What On Earth Is This Sticking Out The Bottom Of My A3?!?!
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2007, 18:35
