Badger5Monster Motorsport
Thread: is this normal
    Feb 2013
    9
    is this normal
    Hey guys,new owner of a awx a4 but have owned a few passats so am familar of there workings but have to ask this..is it normal for the engine to idle at 950 rpm.
    Jun 2012
    Teesside
    448
    Mine idles around the same mate, just got vagcom today so ill scan mine make sure there are no codes, then ill know if its normal
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    sounds about right to me
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    441
    Mines an awx ad yeah it's fine, mine has no codes eieither
    cold start it jumps between 900-1100 for a minute but is fine
    Oct 2009
    Hull
    1,442
    MIne ticks over at 860rpm checked by VCDS
    its supposed to be set from 790 - 910ish according to VCDS
    Feb 2013
    9
    thats good to know that its normal idle,,just seemed a li bit on the high side after coming from a passat
  1. my a6 keeps locking itself is this normal?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th October 2006, 19:38
  2. My dash lights seem permanently on - is this normal?
    By rgb8888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2006, 12:24
  3. headlights are apaulling, is this normal
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2006, 22:52
  4. Picked up S4 - is this normal?
    By imported_SunDiver in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2005, 00:11
  5. Sound on acceleration - is this normal?
    By imported_bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 22:48
