EM TuningSky Insurance
    Sep 2007
    20
    Dropping a 07 engine into an 04 car?
    Hello guys,
    Im (un)lucky enough to own an 04 Avant which needs a new engine & turbo. Its a Nov 04 1.9 TDI 115 PD. Engine code BKE. Quite rare.
    The BKE was used in A4 B7s right up to round 07 iirc. Would an 07 BKE drop right into my 04 Avant, theoretically?
    Jul 2007
    London
    3,074
    Should do... you might have to swap a few sensors round but it's doable !
    FOR SALE:
    Sep 2007
    20
    Would I be right in saying a lot of the B7s are 115 bhp?
    Oct 2009
    Hull
    1,433
    I think all the 1.9 tdi's in the B7 are 115
    I dont think you even need to swap any sensors
    get a copy of etka and cross reference the sensors from the b6 engine codes against the b7 and the loom too while your at it
    I would do it for you but etka wont work on my windows 7!!
    Sep 2007
    20
    Thankyou very much. Will do.
    Whilst Im at it, Id need to check if my current flywheel & clutch are the same too?
    My B6 A4 I believe got the newer type 1.9 engines that went into the B7s. My engine code is BKE - I know for sure there were BKE engines used in the B7s.
  1. Dropping an S4 engine in a 99.5 TQS?
    By Jpc in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th December 2007, 20:57
  2. 1.8T engine into an Octavia?
    By Bigman in forum General Technical / How To
    Last Post: 10th May 2007, 20:04
  3. Engine Number and Imported cars.
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2007, 12:09
  4. Audi LeMans engine into the Q7...
    By god_thats_quick in forum Diesel forum
    Last Post: 8th November 2006, 07:58
  5. AGU engine into A4?
    By macca in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2006, 13:20
