AH FabricationsChris Nott
    Apr 2012
    Lanc's
    9
    Rnse led satnav fitted
    Hi can anyone help I have a b6 18t avant with original audi concert ,,,wasn't keen,, so had LED rnse sat nav fit ,but since having it fit the rear door speakers and sub seem a lot lower than there supposed to be any ideas cheers Si
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Tried adjusting the fader settings?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Apr 2012
    Lanc's
    9
    Yeah adjusted fader but surely there supposed to be balanced fronts n rears n sub without fading as I have fader on 3 o'clock just to get even balance . Is there a wire in the the plug missing for the amp etc to put equal power to all speakers as it wasn't like this with my concert...???
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Do you have Bose?, there is a wiring modification to do on the plug adapter, you have to move a wire, I can't remember which one it is but a quick search on google will tell you everything
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by Evosi View Post
    Nope.
    If you have Bose all the speakers are amplified, so if any speakers work then the amp is powered up.
    If you don't have Bose the front speakers connect directly to the RNS-E and only the rears are amplified, so if the rears produce anything then the amp is powered up.
  1. 8P3 Bi-xenon Led headlights Fitted on a 8P2 S-line 1st i have seen
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2012, 20:34
  2. Led Lights Fitted Pics Added
    By Customboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2012, 20:03
  3. Will the Devil Eye DRL LED headlight fit my B7 Cab??
    By 88mu88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th February 2011, 23:01
  4. LED Sidelights Fitted
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 21:26
  5. Replies: 0
    Last Post: 13th December 2010, 10:47
