JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    Oct 2012
    9
    Exclamation 2003 A4 1.8T (163) Oil Issues.
    Been having some issues recently, with Oil Level indicator randomly appearing. Having checked the oil every time with no problem, and been very careful with the car i finally took it to Brookdene Motors (Watford) to have a diagnostic to understand if there was an underlying issue.
    The diagnostic showed no problems and level sensor and oil pressure checked out ok.
    1 Day later, doing a steady 80 on the M3, when suddenly a slight pullback when accelerating makes me immediately pull over and stop. This was mainly due to the oil light issues and reading some very good posts on this forum about the trials of 1.8T oil issues!
    When turning it over on the side of the road, sounded like a tractor. Left it well alone and got flat bedded back to Brookdene.
    To cut a long story short, the car is currently arse in the air being drained, sump cleaned and oil pickup and pump replaced. It will also have a calibrated pressure test and another diagnostic when complete. To mention, all being done for a reasonable amount of notes by the excellent Jason at Brookdene Motors.
    Small Morale of story, worth a few quid to investigate a little deeper anything that indicates even the smallest issue with oil!!!!
    Will update when the car returns.......
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    Quite a common issue caused by people not allowing the turbo to cool / using poor quality oil.
    The turbo cooks the oil causing sludge - this then blocks the oil strainer.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Oct 2012
    9
    Hi, thanks for the advice. Have only owned the car since November so plead innocence!!
    Have now organised the garage to switch it from Long life service to interval and will also consider a an oil change every 5k-6k.
    Is there anything else on these that i should be aware of / consider so that i keep it in best shape possible?
    Also, have been toying with the idea of a possible remap to make this great car even more fun but this would be new territory.
    Feb 2012
    Liverpool
    1,159
    Quote Originally Posted by Rodgeri View Post
    Get it off the longlife - fresh 5-40w fully synthetic every 6k should keep it in good health.
    Clean out the breather pipes at the top of the engine - these get sludged up too.
    Aside from the issue you have come across the 1.8T engine is bulletproof - definitely have it re-mapped, you wont look back!
    - Weitec GT
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    Oil change every 6 months personally. Awesome block these but just keep them happy and they will serve you well.
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
    Oct 2012
    9
    Cheers guys. Update is that oil pump and pick up all changed and running well, looks like a new turbo is needed as the old one is struggling, especially with a new pump fitted.
    I am being quoted 550 for a Garrat K03 with 1yr guarentee. Sound reasonable or is there better deals out there for a new one?
    Oct 2009
    Hull
    1,442
    check out prices for a refurb on yours think they come in at about £350 - £450 they only down side is your car will be off the road for around a week but the turbo will be as new
    Oct 2012
    9
    Hi Stu_m, thanks for that. Just spoken with mechanic and he is not keen on the idea of a refurb of this turbo, as all they rebuild is the core and so the housing etc is still 80k's old.
    Also, best rebuild price (essex turbos) is £444 inc VAT, so for the saving i may as well get a spanking new one.
    Oct 2009
    Hull
    1,442
    It wont matter if the housing is 4 million miles! it has no moving parts and would be cleaned up like new you really wont be able to tell the difference!
    like I say though the dwon side would be car off the road while it gets done and if its still drivable now and you need to use it for the £100 you save it could cost you more in alternative transport!
    Oct 2012
    9
    True. Will have a think on and make my decision after a bit more furious researching!!!!!!
    Btw, do you have any good recommendations for rebuilders?
    Feb 2012
    Liverpool
    1,159
    Why not use it as a chance for an upgrade?
    Some variants of the K03s/ K04 turbo are a bolt on upgrade.
    If not, you could have yours rebuilt with different internals (compressor wheel.etc) - Combined with a decent re-map may see a good power upgrade!
    I have used CR turbos in the past - I also think there is a user on here (cant remember his username) who rebuilds turbos.
    - Weitec GT
    Oct 2009
    Hull
    1,442
    Ive heard good things about midland turbo might be worth a try
    Sep 2011
    75
    send beachbuggy on here a PM now, he can either rebuild your turbo standard or rebuild with Ko4 hotside internals and that will really let your car breathe nicely. very reasonable pricings too
  1. Oil issue!!!
    By skol in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2011, 20:00
  2. Help Needed... S3 Oil issue
    By MattW86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2011, 18:03
  3. Oil issue.....any suggestions?
    By tspar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2010, 05:32
  4. Help with OIL Warning 2003 A4 Cab 1.8T
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2009, 05:04
  5. Allroad - 2003 with 110k - worth it? - issues?
    By Caz in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th May 2005, 13:44
