EM TuningJMB Retrofits
    Oct 2009
    77
    Best way of fitting the lower VOTEX to my Audi Sport TDI bumper
    Picked up a VOTEX lower with grilles off ebay
    so to attach it to my current bumper - how to go about it..
    im slightly confused because after a quick google search theres different opinions
    some keep the current lower and attach it over it - i must admit - i didnt think this was possible - but seems it is
    others remove lower and fit it
    what is the easiest way?
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    437
    Quote Originally Posted by Black_B6 View Post
    Here mate, this is a thread started by my mate Paul, it will explain how to do it
    Votex Lower Fitment!
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    The correct way as the instruction manual that the skirt comes with tells you to fit over the top, fitted mine a couple of months ago.
    Did you get the 2 little plates that fit just inside the rear of the inner wheel arch they get sandwidged between the votex skirt and inner arch?
    I sprayed my lowers satin black where you could see it through the mesh and it works a treat cant see it at all.
    Oct 2009
    77
    Cheers for that mattyB6!
    Quote Originally Posted by dpbayly View Post
    Im awaiting delivery - so not got it yet but i dont think its with the inner wheel arch plates - at least it wasnt advertised with them anyway..
    So if i dont get them - is it still fine to put it over my lower bumper or do i need them?
    My car is black - so i guess i can put it straight over eh - without worrying about spraying the current bumper... but i need to remove grilles though.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Correct remove the stock grills,
    If the plates are missing it shouldn't cause to much of a problem they are there to be used as a spacer so might have to knock something up but offer it up and see you may get away with it.
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,317
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    part number for the plates anyone
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
  1. Carbon fibre DTM spoiler, any idea on best way to fit? Tigerseal or 3M tape?
    By Beni786 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th February 2012, 06:46
  2. Best way to remove the block? What piston size?
    By StaceyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2011, 18:59
  3. Anyone know the best way to fit a water pump on s3 ??
    By motfree in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2010, 14:41
  4. Whats the best way to bleed the clutch?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2010, 14:00
  5. Best way to leave the motor whilst on deployment
    By audibhoy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2010, 21:31
