JMB RetrofitsAH Fabrications
Results 1 to 16 of 16
Thread: servo
    simon.m's Avatar
    Oct 2009
    2,746
    servo
    hey guys any one no what changing a servo involves may have to change mine as im told the peddle is to hard iv never had a problem with it and its gone through 3+ mots but this time im told it may need a new servo
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Are you sure the plenum chamber isn't flooded? I've heard of people with this problems reporting servo issues as water gets in there and then freezes.
    simon.m's Avatar
    Oct 2009
    2,746
    to be fair iv not looked at that mate its always been dry but i guess there is a chances its got some in it but my peddles have always been fairly hard they guy says it should be soft ie when you brake peddle should go at list1/2 way down where as mine dose not. also with car off when you pump the peddle it goes rock hard start the car foot still on peddle it only goes down 1inch max till you drive off then when you push it itssay 2 to 3 inch ish but its always been this way
    Lancaster
    1,788
    Is yours a 1.9 tdi?
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    yes mate 1.9 100bph
    Lancaster
    1,788
    Whether it's the same on the a4 or not I'm not sure bud.
    I bought an A6 for the Mrs and the brakes were rock solid, I never felt confident with the brakes. I put a new servo in. Easy enough task. I could run you through it, but I'd have to have a look under the bonnet again just to refresh my memory. It took me about 1-2 hours.
    It didn't fix the problem at all. URGH!!
    What the problem turned out to be was...
    On the rear of the engine, there is a fuel/vacuum pump. The outlet connection for the vacuum becomes loose over years. It's a pressed fitting over a metal connection. I took the vacuum unit off, pushed a good oil resistant sealant into the gap and carefully knocked over the edges of the unit with a light hammer. Prior to this, it moved around ALOT in its housing. Now it's rock solid and the brakes are fantastic.
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    that sounds like my problem mate i no the pump your talking about and one of the pips is loss does not look like it fits right so maybe that
    Lancaster
    1,788
    If you reach round the left side of the engine. If it's loose you'll be able to wiggle it.
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    yeah it is loose for sure how can i fix it
    Lancaster
    1,788
    Take the pump off for ease of work.
    Get some Loctite 5910 from Halfords. With it on your finger, push a small amount into the gap all round. Then gently tap over the edge so it clamps back down on the metal. Refit and leave for a few hours for the sealant to fully harden.
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    thank you so much its in a work shop at mo being looked at but im 99% sure its that but the garege thinks im wrong and think its not just the pip but the hole thing if any thing or the servo
    simon.m's Avatar
    Oct 2009
    2,746
    can the vacuum pump get oil in it ? the garege has told me it has oil in it
    Lancaster
    1,788
    It might pick up oil from the EGR and wastegate?
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    well he faild its MOT on it after i told him what it was he said oh no the pump is nackerd as its full of oil so the oil seal insaid has gone. so i asked if he took it off and he said he was just stripping it down as we speak i give him 20mins and whent to see him he had put it together again so i now have my car back parked up will take it off tomrrow and do as you did just hope there is no oil seal gone. but if you say it could be from egr then a clean will sort that im sure
    Lancaster
    1,788
    Failing that, there's plenty on ebay bud.
    To do: None yet.
    simon.m's Avatar
    Oct 2009
    2,746
    yeah just need to find the right one for mine no way can i pay 300 for a new one
  1. Iced brake servo?
    By PhatBob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th January 2009, 21:16
  2. Brake servo has died.....
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2008, 15:31
  3. Broken nipple on Servo line, important?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2008, 23:23
  4. Vacuum caused turbo & brake servo problems
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2007, 18:22
  5. MY98 Brake Servo Hose Recall
    By DaveN in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2004, 10:50
