AH FabricationsEM Tuning
    Jan 2013
    2004 a4 radiator fan/ cooling issues, help!
    Hi all,
    I'm new to this forum, currently owning an a4 1.6 avant sport and previously owning an '88 UR, anyway on with the problem!
    my a4 currently has an issue with warming up, the problem is just occasional at the moment. The engine is just not getting up to temperature, even on long journeys it will sometimes not raise above 70 degrees, The radiator fan seems to come on early, causing this problem, also occasionally stays on for a few minutes after turning the car off.
    I think the problem will be the temp sensor in the radiator (hopefully not the thermostat!), can anyone give me some advice with what the problem is most likely to be? And if possible some part numbers?
    thanks in advance,
    andy
    Oct 2009
    Hull
    1,437
    Its more then likely the stat
    The stats job is to keep it at 90 or there abouts once it reaches 90 it will open and let cool water in from the rad and hot to the rad to be cooled
    no amount of fan turning will cool the car if the stat is closed
    it sounds like your stat is stuck slightly open
    the fans been on could be a different problem
    If its not your stat then the next thing would be your temp sensor
  1. 99 S3 Cooling (radiator) Fans On/Off Constantly
    By OW29 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2012, 21:43
  2. Help with radiator fans please urgent.
    By DSG TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2011, 11:20
  3. Replies: 2
    Last Post: 6th June 2011, 15:25
  4. Help with radiator fans on all the time 2.0 tdi 140
    Last Post: 19th January 2011, 20:50
  5. Audi A3 radiator fan and on dash thermostat troubles. Help!!
    By J4MES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 10:05
