JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Jun 2012
    Teesside
    448
    What is this part??
    As title was doing a service on the motor before christmas and noticed this, that seems to of been hacked in the past, the silver round component, not sure what its purpose is, but my car runs fine, no faults apart from engine mount and one from rear doors not locking as they should.....
    Lower image shows the pipe thats been hacked...
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Sep 2009
    Rumburgh Suffolk
    193
    Keep trying to figure out the angle, in the bottom pic is that the underside of the ABS modulator??
    In the larger cut off pipe, the thing just after looks like a one way valve, commonly found in vacuum lines.
    I'm guessing it is a TDI?, if so you should be able to see and follow the vacuum feed along side the inlet manifold back to the pump.
    Where does the other end of this cut pipe go too??
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Jun 2012
    Teesside
    448
    the top picture ideally should be 90 degrees counter clockwise, then you would be looking at it from infront of passenger headlight, and the bottom pic is as you say down the side of the abs unit,
    Sep 2009
    Rumburgh Suffolk
    193
    I have to admit when I service mine I don't look up there too often, I'll service it in the spring and will have a look, can only say try and trace the pipe back and see where it goes...
    Someone else may know better hopefully..
    Mark
    Jun 2012
    Teesside
    448
    Sorry mate seems im making this more confusing than anything the part im trying to identify is the one the broken pipe goes into, the one thats circled and has arrow pointing to it on this pic.....
    Sep 2009
    Rumburgh Suffolk
    193
    I'm sure on mine that black enclosure around it is empty, I'll try to have a look tomorrow to be 100%. Other than that mate, sorry but I really haven't got a clue.....
    Mark
    Jun 2012
    Teesside
    448
    Found out that this is a vacuum pump, im still none the wiser what it is for though? as both the vacuum pipe and electrical plug have been cut, im guessing it may have been bypassed?
  1. Replies: 4
    Last Post: 6th February 2011, 19:40
  2. HELP: what is this part number? 8p3 807 434 g 1rr.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2010, 10:42
  3. what is this part????
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2008, 19:34
  4. what is this part making the noise - pics inside
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2007, 17:02
  5. Audi S3 - What is this part in these photos?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2006, 11:52
