Monster MotorsportEM Tuning
    Mar 2009
    LED Door markers
    Hi guys and girls, I haven't posted on here before but i have been a follower for some time now. I have a small question and maybe its been discussed before so im sorry if it has.
    My problem, I have replaced all the door markers(red) with LED's, i know they dont make a huge amount of difference but never the less i wanted to.
    On replacing the bulbs with LED's i closed and opened the door only to find the LED stays on for what must be 1 second, any ideas on the fault?
    Thanks again in advance for any help.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    I had a similar issue when i was taking a power feed off the main dome interior light i found even when off there was power being feed to the light but only 4v instead of 12v and im guessing the with the LED's 4v is enough activate them the only way round is to fit CAN BUS led bulbs that might cure it
    Mar 2009
    Thanks for the reply, Yes i thought the same, so i purchased can bus LED's still the same issue!
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    In that case you will need to connect in parallel with each LED a 2w 220ohm resister this will fool the can bus system and sort your issues.
    One like these (part number D220K 2W 220 OHM)
    http://www.maplin.co.uk/metal-film-2w-resistor-5729
    Mar 2009
    Excellent, thank you very much for your help!!!
  1. Interior Door Handle LED Lighting Kit
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2014, 21:40
  2. Door marker light
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2012, 20:34
  3. Alarm buttons on door.LED`s not lit.
    By qawsed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th April 2010, 18:22
  4. [Help] LED light's on the interior door handle
    By griffin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2010, 23:25
  5. Door pin led's
    By S90GAV in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2008, 11:54
