Volks AutosSky Insurance
    Oct 2010
    11
    new stereo what do i need to know
    just about to change my headunit in my a4 quattro sport anything i need to get or know ?
    Oct 2009
    Hull
    1,437
    you putting after market one in ?
    Oct 2010
    11
    yea prob be pioneer so i can run iphone etc the car does have a factory sub under parcel shelf will this work still ?
    Oct 2009
    Hull
    1,437
    you have an amp for the rear speakers which will make them louder then the fronts so you would need to either fade them out to balance it re wire so you remove the amp or you can get like a resistor which steps it down from the head unit not sure where from though as I have never seen one mentioned on here but I have one on my car!!
    you also wont have a switched live to turn the radio on and off as it works off can bus you can take one from the rear of the fuse box or you can use a wire under the steering column that goes to the ignition switch....this is a really thin wire and would need to be run through a relay as it wont carry the load
    not sure on the sub mine seems to work though
    Oct 2010
    11
    ahh cheers mate
  1. Removing The Hood On My 06 Cab, What do i need to know?
    By DOLPHIN DIESEL in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2012, 22:48
  2. Need a new horn! What do i get??
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2008, 17:14
  3. removing a dump valve - what do I need to know
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2007, 16:57
  4. Need New Tyres - What are good?
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 10:26
  5. What does a nubie to the S3's need to know?
    By S3BeemerBeater in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 18:12
