EM TuningChris Nott
Thread: MFSW
    Feb 2012
    Glasgow
    190
    MFSW
    Hi guys.
    Sorry to dig this up again but have done a bit of searching and can't seem to get a definitive answer.
    I have managed to get my hands on a mfsw from a 2001 s3 which looks identical to the standard 4 spoke wheel on my 04 a4 apart obviously from the radio buttons (3 down each side of the air bag). Now my car has full dis and cruise so I'm fairly sure I have the correct steering wheel control module. My question is what else am I likely to need to change these over?
    Cheers in advance guys!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,273
    Idiot's Guide to MFSW Install + Everything you want to know! | Audi Forum
    Dont know if this guide is of use to you Ian, but may be worth a read. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    I wouldn't be so sure that you have the correct Steering Module for MFSW, you can easily check this by undoing the 2 T8 screws securing the top cowling to the bottom, lift the top cowling and read the part number. You can do this with the steering wheel still on.
    If you have the correct Steering ECU then you'll also need a new airbag harness and a slipring.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Feb 2012
    Glasgow
    190
    Re: MFSW
    Thanks for the replies so far guys.
    Sandra I had read through that previously and unfortunately its for fitting a b7 steering wheel to a b6 so wasn't sure how much would apply when fitting what I suspect is a b6 steering wheel.
    Jb I read elsewhere on this forum that the highline steering wheel ecu required for cruise and dis also allowed mfsw?!?
    Apr 2012
    lincs
    202
    ross tech say:
    Cruise Control Retrofitting (8E) - Ross-Tech Wiki
    so according to them highline is only needed for steering wheel heating - hence mid-line, if you have it, may work anyway.
    the parts catalogue only list one slip ring right up to 2005
    10 8E0953541E
    cancelling ring with slip ring and steering sensor / F >> 8E-4-400 000
    so that's a bit odd
    will look further into it
    And
  1. Parrot Phone Kit with MFSW controls
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th January 2008, 17:35
  2. Retrofitting a MFSW S-Line
    By StevenAFC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2007, 10:41
  3. MFSW phone functions not working
    By Vertigo1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th September 2007, 08:05
  4. Bluetooth without MFSW
    By g-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2007, 08:05
  5. MFSW ? HWW ?
    By Crafty in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2003, 14:34
