Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    alloy wheel question
    I have bought some 8x18 et 32 alloys and was wondering what tyres fit this size rim and would this offset give it a wider or narrower stance? Would i need spacers to fill the arches?
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    wider or narrower than what? if you had 8x 18 with an ET of 45 they would sit further inwards than 8 x 18 with an ET of 32. Sounds like they will be fine and fill out to the arches just fine. I am not entirley sure the correct tyre width for those as I run slighly stretched tyres at 215 up front and 225 on the rear, so I think that 235 is what you would need but someone who knows will be along and input I am sure !
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
    munchkincoupe's Avatar
    Aug 2010
    971
    Will give it a wider stance so no you won't need spacers but you may get some rubbing of the tyres on the arches on full lock depending on tyre size
    A lower number offset than your standard wheels moves the wheel out of the arch!
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Offset sounds good to me, thanks lads. Just need the correct tyre size now
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    All A4's with 18" 8J wheels left the factory with 235 tyres. Some people fit 225's as they're cheaper, and some fit 215's if they like the stretched look. So it depends what you want.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Thanks mate, whats an ideal profile?
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    My wheels are 8x18 et35 so mine without spacers sat 3mm further in the arch than yours will fit mine also had 235/40 18 tyres fitted all round if your's is a quattro its best to run the same size tyre front and back to keep the rolling radius the same,
    Here's how they looked in the arches:
    Im now running the same wheels but with 20mm spacers rear and 15mm spacers front but i also changed the tyres to 225/40 18 to make it rubbing free, i took this route as i like the wider look.
    How it looks now in the arches:
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    looks smart as hell that mate, think al go 225/40 thanks alot boys
  1. alloy wheel question
    By tedster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th November 2009, 15:59
  2. Alloy Wheel Question
    By H2o-uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2008, 17:55
  3. Alloy wheels question
    By FoxyRoxy in forum Volkswagen and other VAG
    Last Post: 10th June 2007, 14:48
  4. alloy wheel question plz help
    By BAMS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2007, 13:48
  5. Alloy wheels question
    By johndow in forum Handling
    Last Post: 22nd December 2005, 15:34
