Chris NottEM Tuning
Results 1 to 14 of 14
    Mar 2012
    188
    Help please, Rear light flashing
    I'll do my best to explain what is happening. Upon turning the key in the ignition i get a warning beep and displayed in the DIS is the check bulb sign and it says drivers rear light. This all happened first time in the dark on wednesday.
    So i get out of the car to double check which light is out and on the drivers side the light is out but the brake light is flashing steadily on and off about once per second.
    Any ideas what this could be? First i thought ABS but the abs light comes and and goes out as it should and the abs is still working when braking heavy on ice / snow etc.
    Last week when coming back from work in Warrington which is a 2.5 hour drive the traction control light came on for the last 10 minutes of the journey. Not sure if this has anything to do with the above.
    Any advice or help would be appreciated.
    Lancaster
    1,780
    Quote Originally Posted by duffy78 View Post
    Sounds like the brake light switch.
    To do: None yet.
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    224
    How long have you had the car? If its a recent purchase check that it hasn't has LED bulbs fitted at the rear. Faulty LED bulbs flash if there on their way out.
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Have you tried another bulb?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Try replacing the bulb first, might be shorting somewhere.
    Mar 2012
    188
    Going to try a bulb tonight.
    Mar 2012
    188
    Go to the top of the class that man who suggested led bulbs.
    Look at this mess
    Led bulb gubbins has melted into the side of the light clusters. Clusters filled with water and caused a short!
    One of the clusters is all blackened with charcoal so I'm pretty lucky that there wasn't an electrical fire!
    Ill be putting it all back to oem and sealing the clusters as best I can
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Christ what a mess.
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Wow, that's horrendous! Luckily nothing serious came from it. Is the car new to you then? It seems like they've mounted the power resistors to the plastic? Silly sausages!
    VagCabby's Avatar
    Apr 2012
    224
    Wow that's bad! As you said lucky it didn't set on fire. Some people shouldn't attempt electrics. Unbelievable. All that for the sake of a bulb.
    Mar 2008
    Dorset
    13,856
    So it's a standard cluster with a led bulb been put it it, and resistors melted the housing? Eeek.
    Mar 2012
    188
    I've had the car 8 months.
    Any tips on how to reverse engineer this? If someone could link to a page showing an install I should be able to work it out.
    VagCabby's Avatar
    Apr 2012
    224
    I think your best bet would be to remove all that crappy red insulating tape so you can see what your dealing with. I assume they have tapped into your original wiring loom. I'd just snip or unsolder any aftermarket wires coming off the loom then just fit standard bulbs.
    Mar 2012
    188
    All sorted now. I snipped out all aftermarket wiring and installed some normal filament bulbs.
    Thanks for all the advice.
  1. Help please ESP light came on and brake lights staying on when driving
    By ash1809 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th December 2011, 20:31
  2. Help Please - Rear SB Window Seal
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2011, 20:08
  3. Help Please - Rear Bumper Diagram/Plastic Trim Question
    Last Post: 12th September 2011, 12:57
  4. help please warning light
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2011, 08:11
  5. HELP PLEASE!!! FOG LIGHT HELL!!!
    By jmw1200 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2009, 17:28
