Chris NottBadger5
Results 1 to 13 of 13
    Apr 2012
    lincs
    210
    DIS and Cruise - Done
    I fitted DIS and Cruise over the weekend using the various guides (QJ's sticky, etc) but I noticed that there's a few gaps to catch one out.
    One of the things that is rarely explained properly is the Pin 1 'earthing' or washer bottle problem. Pin I is on the dash multi-plug (the Blue one) behind the Tacho NOT the speedo as some guides say, (that's green).
    There's a very good post here, by Fourcircle (about half-way down) that explains it in pictures:
    DIS retro fitted but button blanks the display
    However you DON'T want repair wire 000 979 133 (A, B or E) you need 000 979 009 for the dash plug. As that has a pin 1 female end on it already.
    You can use a "twisted end" but for a couple of quid the repair wire is a better bet long-term.
    There's a guide to all repair 'wires' here:
    http://www.motor-talk.de/forum/aktio...hmentId=699152
    Repair wire 000 979 133 (A) is for the washer sensor itself and you need one or two of these. (you can use one, halve it and splice an earth on one half and an extension to your pin 1 wire.
    I managed to find a bargain brand new 'R' B7 SCCM and a complete stalk set from a B7 in as new condition.
    If you are using a 2nd hand SCCM you'll need to use the learn VIN coding in VCDS. I've read that most (or a lot of) A4 B7's come with a highline module in them so it's worth looking for a 'breaker'. I'd already bought the new 'R' module (a really lucky find) but the stalk set I later found had all 3 stalks and a B7 slip ring and a 'Q' SCCM.
    As Ross-Tech imply B7 modules are backwards compatible with B6.
    Cruise Control Retrofitting (8E) - Ross-Tech Wiki
    I didn't have to wire the SCCM to the Engine Control Module (I believe this was for early SCCM's). It worked once the engine was coded for cruise (adapted login)
    I bought a complete standard cowl set for a tenner and being a tight git cut it to suit 'cruise':
    You really need the indicator stalk off the car to do this accurately, to line them up and take the relevant measurements.
    Measure centre to centre of the two stalks and then a semi-circle about 19mm, i did it by 'eye' with a soft pencil!
    I just drilled inside the outline and cut it out!
    File or dremel out the remainder and keep trying it. The cruise stalk actually needs to sit slightly lower than the 'arc' of the indicator cut out to allow the top and bottom cowls to fit tight together.
    30 minutes and saved about £25-30.
    and in-situ:
    I'll extend this when I've sorted my pictures of the washer bottle sensor install.
    Cheers And
    Dec 2012
    Hampshire
    137
    The DIS is something that I want to upgrade at some point, so this thread is just what I needed.
    Dolphin Grey B6 A4 Avant 1.9tdi
    Mods so far: Allard EGR delete pipe, Shark remap, Bilstein B12 Sportline suspension
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Archemist, thanks!! I'm fitting cruise tomorrow, and have had a look for a guide as to how to modify the steering wheel cowling as I too am tight I just need to pick up the two screws tomorrow morning for the cruise stalk.
    Excellent write up, although it says some of your pics aren't available. Are these missing pics, or have you just changed links?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The forum has always lacked a really good how-to for DIS install from start to finish! Thanks for adding to the missing bits, if you want to try and write a complete guide that would be very helpful, as it's probably the most asked question!
    PS, a couple of the pics aren't working.
    Apr 2012
    lincs
    210
    i'll give it a go when i've chance james - hopefully pictures now working!
    crazy88's Avatar
    West Yorkshire
    4,806
    Yep, the extra pictures are working and perfect timing for me tomorrow! Cheers again mate.
    crazy88's Avatar
    West Yorkshire
    4,806
    I got my cruise fit today finally. I had another hold up in that I didn't have a torx t55 to remove the steering wheel, I thought I did...but clearly didn't ha!
    All working fine, and the guide as to cutting the cowling was great. Cruise works a treat so far, I feel like I now have auto-pilot.
    For anyone wondering, I have the 'Q' version of the SCCM, which I believe is from a B7 and it is working fine. Maybe one day i'll use the highline features and get me some steering wheel heating
    Thanks again for the guide!!
    Apr 2012
    lincs
    210
    well done - i spent a smidge over 100 notes on DIS and cruise (not including VCDS!) - worth every penny
    post amended to show the t55 tool i got (it's a 12 spline bit)!
    oh no i can't edit and old post d'oh
    here t'is 5pc 1/2" drive spline triple square socket BERGEN AT848 | eBay
    If you want an authentic wiring appearance cloth tape's a good idea:
    New Wiring Loom Harness Adhesive Cloth Fabric Tesa tape | eBay
    And
    crazy88's Avatar
    West Yorkshire
    4,806
    I luckily already had DIS, so just needed cruise and it set me back £75 for the stalk and module.
    If I hadn't already got DIS I think i'd have done this a long time ago when i first got the car. The screen only showing 'miles to empty' would have done my head in!
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by crazy88 View Post
    I leave mine on that 95% of the time anyway!
    crazy88's Avatar
    West Yorkshire
    4,806
    Really? I always leave it on journey time. Rarely I flick to avg mpg to see how heavy my foot is, but the majority of the time it's on journey time.
    I don't like the distance to empty, it gives me false hope. The first half of a tank it basically says i'll get over 600 miles, and the second half I am fighting a battle to get 500 these days. Last fill up was 430 miles Should have got a 2.5tdi or 1.8T!!
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    I'd like to fit cruise on mine. Already got DIS. It just seems that money and time never seem to coincide.....
    crazy88's Avatar
    West Yorkshire
    4,806
    I was the same Alan, it only took me 3 years to get round to it! I'm yet to fully experience it, i'll be popping on the motorway tomorrow to give it a proper trial run.
  1. Retrofitting DIS and cruise
    By Ian-83 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th January 2013, 17:07
  2. Help! Esp and brake lights on after DIS and cruise fit
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 15:59
  3. Fitting DIS and Cruise
    By BlackQuat in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2010, 18:26
  4. Who Wants Full DIS and Cruise?
    By chrisash32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2010, 22:06
  5. VAG Com and Cruise Control
    By S-T in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2006, 00:47
