EM TuningChris Nott
Results 1 to 9 of 9
    Dec 2012
    Hampshire
    137
    Symphony Stereo problems
    Ok, I think my stereo is the Symphony version, it has an integrated 6 disc changer and tape deck. I got into the car this morning and the stereo wasn't working, it lights up, but there is no sound and no display. I've tried turning it on and off and nothing happens, still sits there with the lights on and no display. I've pressed every button, with a quick press and a long press. Still nothing changes.
    I have just been out to the car to get something and noticed that it is still 'on'. The lights are showing but still no sound or display. Any ideas because I'm stumped?
    Dolphin Grey B6 A4 Avant 1.9tdi
    Mods so far: Allard EGR delete pipe, Shark remap, Bilstein B12 Sportline suspension
    kite's Avatar
    Oct 2007
    East Berks
    675
    Re: Symphony Stereo problems
    Pull the fuse or disconnect the car battery for 10mins to force a reset
    A4 (b6) 2.5 TDi QS Saloon.
    Mar 2009
    471
    Not sure how to advise on a fix for this but I have my one for sale if you can't fix yours and want to replace it like for like.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Dec 2012
    Hampshire
    137
    Thanks Kite, will try it in a bit.
    Just googled and it looks like fuse 37 controls the radio.
    @rjm180 - Thanks but if I can't get it solved I will probably change it for the other one so I can play mp3's.
    Dec 2012
    Hampshire
    137
    Serial posting to ask, are the Symphony stereo's coded before I go ahead and disconnect the battery?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by Malfuss View Post
    The Symphony II+ (larger display, no cassette slot, plays MP3s) uses a different antenna diversity system to the Symphony II so you'll get worse radio reception and it will log fault codes.
    IIRC all the Series II and II+ radios remember the VIN so there's no need to re-enter the PIN code if it's in the original vehicle.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Dec 2012
    Hampshire
    137
    Thanks PetrolDave, as far as I'm aware it's the orginal unit, so here goes, back in 10!!
    Dec 2012
    Hampshire
    137
    Sorted, thanks all
    and for the record it was fuse 39.
    Mar 2009
    471
    Good Result
  1. Weird Stereo Problem
    By MartinM in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th February 2006, 09:28
  2. stereo problem
    By Indian in forum In-Car Entertainment
    Last Post: 11th October 2005, 20:04
  3. Stereo problem
    By Indian in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 22:33
  4. Symphony CD Problem
    By Bayliner in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th December 2004, 16:54
  5. Concert stereo Problem
    By Dylarolla in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 17:45
