AH FabricationsVolks Autos
Results 1 to 12 of 12
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    1.9 tdi warning light???
    Right, occassionaly from cold or on a long journey i get a warning light on the dash, in my experience i would say its a back brake warning light basicaly this (O) haha getting technical here
    Car has no brake lights out and has recently had new back pads fitted, now i seem to think i have read somewere this is a fault from audi and if i go to them they will fit a relay of some sort to stop this, is this correct? If so where does this relay go as there is no way im paying audi 7million sterlings to fit a relay. This light clearly isnt a problem causer its just annoying cruising down the a1 and hearing a beep then this appearing on the dash (O) or starting from cold and its pops up right away. Normaly ignition off and on again and it goes but sometimes it stays.
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Is it orange? Typically shows up when brake fluid is low, or the front pads are low. It can come up if there's a sensor issue on either part too. There is no wear sensor on the rear pads.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Aye there is a similar light that says brake im the middle of the circle, i will take a pic tomorrow so you can see which one it is
    Oct 2009
    Hull
    1,442
    this one
    Or is it a big red one that fills the DIS
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Thats the one mate above the temp, not handbrake in top right
    Oct 2009
    Hull
    1,442
    brake pads sounds like you have a loose wire or they are close to been replaced
    Its only on the front
    Not sure if the orange one is for fluid too but easy to check your fluid
    ps the top right is hand brake!
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I know thats what i said haha thanks mate i will check me front pads at the weekend and al check me fluid tomorrow. Just find it strange how it comes on when cold but if i start it warm it dusnt come on. Also if i hold the check button everything comes back 'ok' even if the light is on, had me mac tools obd scanner on it tonight aswel and no faults are logged
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Thats definately a front brake pad worn indicator. If the brake fluid drops too low, it puts the big red warning light up in the whole DIS display.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by gary3306 View Post
    Correct re the brake fluid light being red, I was wrong saying it was orange.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Thanks lads al get it sorted
    audilad9's Avatar
    Jan 2013
    Highlands
    257
    My car does the exact same as yours Ollie, has done for ages, same as you I turn off and on again to clear. I have new discs and pads all round. Pad wear wires all seem ok. Be interesting to hear if you find a fix. My ABS seems very sensitive, cuts in at the slightest thing.
    Nov 2012
    sunderland
    73
    Does That Mean My Bake Fluid is Low, it Goes Off If I Turn Car On And Off
  1. Audi A3 2.0 TDI - Glow plug warning light flashing....
    By Julian1968 in forum The Welcome Section
    Last Post: 20th May 2012, 20:00
  2. Replies: 7
    Last Post: 1st February 2012, 13:09
  3. a4 2.5 tdi red breake warning light flashes on start up!
    By vorsprung dork in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2011, 23:05
  4. coolant warning light DIS 2.0 TDI (2005)
    By john_cook in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th December 2007, 17:10
  5. A3 TDI coil warning light!!!!
    By Daz A3 TDI 130 in forum Diesel forum
    Last Post: 1st August 2006, 03:09
