AH FabricationsVolks Autos
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    help needed asap
    hi im in the middle of putting my enginge back together and i dont have a book so does any one know the torque settings for a cam carrier for a 2.0 alt engine please cheers
    If you give a mouse a cookie......
    He's gonna want a glass of milk....
    vorsprung durch technik
    Oct 2009
    Hull
    1,442
    would it be called a bearing ladder?
    If so its a new bolt jobbie and they are two stage
    stage 1 - 8nm or 6lbf ft
    stage 2 - angle tighten 90°
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    not sure dude its the luminium cast the bolts the cams down
    Oct 2009
    Hull
    1,442
    Im pretty sure it is the bearing ladder as there is nothing else in the haynes manual for it
    If it hold the cams down then it will have bearings in it and it will be ladder shaped
    Oct 2009
    Hull
    1,442
    just done a quick google and that is the right settings
    it is a bearing ladder
    its says VW but its the same engine
    http://www.volkspage.net/technik/ssp/ssp/SSP_322.pdf
    tazzy baby's Avatar
    Rookie
    Feb 2009
    south wales
    545
    cheers butty
  1. Brake upgrade help needed ASAP!
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2010, 16:40
  2. HELP NEEDED ASAP!!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 11:24
  3. Adapter help needed ASAP PLEASE
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2010, 00:40
  4. 1.9tdi(110) not revving, help needed ASAP
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:21
  5. Exhaust/Engine Question Help Needed ASAP
    Last Post: 21st January 2009, 17:36
