Results 1 to 21 of 21
    Dec 2012
    47
    What affects MPG???
    I have an Audi A4 1.9 tdi sport estate.
    It does 47 mpg on motorway runs...Not bad, but I was hoping it would be a little better. I do 75- 80 mph all the time and accelerate gently. What can affect the MPG? (Apart from the obvious ones like tyre pressure, poor running, etc.) It runs smoothly with no fault codes or known faults....Could the MAF or MAP cause this without symptoms??? The coolant sensor was recently changed for one off ebay and the thermostat was changed too....it now sits at 90 degrees most of the time.
    Oct 2009
    Hull
    1,440
    if your getting 47 at 70-80 then theres nothing wrong there its about right
    try slowing down to 60-65 and it will increase
    when a maf is on its way you dont get no difference in the drive
    the cold effects it too
    Dec 2012
    47
    Quote Originally Posted by stu_m View Post
    Thanks buddy! Is it worth changing the MAF or should I wait until mpg drops substantially?
    Oct 2009
    Hull
    1,440
    I would get it checked with VCDS first if you suspect it is bad
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    sounds about right... I bet you get around 55-60mpg at 60mph, so try slowing down if economy is THAT important.... personally I'd settle for 47mpg at that speed.
    I get about 60mpg at a steady 50mph, 40mpg at 70mph, 35mpg at 85mph and 30mpg at 100mph.
    LostBok/BahnStormer77
    Sep 2009
    Rumburgh Suffolk
    188
    All big electrical loads will drop it too, demisters, lights, fans etc.. all the stuff you need this time of year. 47 isnt far out, most I've ever had from mine is 50..
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Dec 2012
    47
    Sorry guys, i should have said i'm getting 44 mpg at 70 mph....I'm wondering if the Maf might need changing?
    Dec 2012
    47
    Even at 60 mph, it still stays late 40s on the trip computer....I don't have any fault codes. Are tests any tests or easy parts to change to see if that helps???
    Oct 2009
    Hull
    1,440
    forget the DIS work your mpg out tank to tank
    Dec 2012
    47
    Yep I did that....590 miles and put 60 litres in...= 43.76 mpg. That was mainly motorway at 75 mph.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    What affects MPG???
    How much fuel economy do you think you loose with keeping heated leather seats on ?
    Anyone ???
    I bought a convertable in the wettest country in the world who says Scotsmen dont have a sense of humour !
    "Lets fire up the Quattro" DCI Gene hunt,,,,,,,ashes to ashes
    pauldazzle's Avatar
    Cardiff
    634
    Coolant Sensor off ebay
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Dec 2012
    47
    Do you think that might be causing trouble Paul? Should i get the gsf one for £17
    Dec 2012
    47
    My father's B5 currently has the heated seats on all the time and he's still averaging 51 mpg and that's mainly running around the villages, so I guess it has little affect.
    Quote Originally Posted by fallmonk View Post
    Anyone ???
    Oct 2009
    Hull
    1,440
    its best to replace with OE all the time if you can
    But Im'm not sure you have a problem at all
    Dec 2012
    47
    Thanks Stu, it's just my brother has a 115 pd and gets 55 on motorway at 70....i was hoping for similar. Does OE mean it's genuine audi part or is it just the equivalent? Thanks again
    Oct 2009
    Hull
    1,440
    is his the B6 or the B7? and is that worked out off the DIS?
    My brother has a B7 2.0tdi and his DIS shows 55mpg average but he doesnt get that if worked out tank to tank he gets roughly the same as me 44-48 average
    OE means original equipment so audi parts the actual term is OEM (original equipment manufacturer) but every leaves the M off
    If you think you have a problem get it scanned for codes and the MAF checked too check the VCDS map for a user near you. What is your location? I'm in Hull and have VCDS if I can help
    Dec 2012
    47
    His is the B5 with the 115 pd engine and it was calculated by brimming the tank. I had it scanned and no codes came up except for an unidentified Ecu and aircon codes. There's no compressor in it hence those aircon codes. I'm in Bristol. Is the Maf easy to check? Thanks again.
    Greeny233's Avatar
    Mar 2011
    Llangollen
    673
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    What affects MPG???
    My 1.9tdi sport Quattro Avant does 47mpg on a long run sat at 70-80mph if I want over 50mpg I have to slow down to 60mph. 47mpg is good for such a big heavy-ish car. You could always fit a 90bhp A4 B5 engine, my old B5 used to do 50mpg everywhere and 60+mpg on the motorway.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    AudidriverA4's Avatar
    Sep 2012
    181
    Quote Originally Posted by Greeny233 View Post
    That's excellent fuel economy, there has to be something wrong with my FWD 1.9 tdi 130 bhp because I'm only getting around 40 mpg
    Although my car is driving perfectly and no warning lights on dash
    Greeny233's Avatar
    Mar 2011
    Llangollen
    673
    What affects MPG???
    Mine has been remapped, but I doubt that would make much difference, the biggest effect on economy is the driver. Even a Prius has to be driven economically otherwise it will only do mid 30's mpg.
    I always use Shell V Power diesel in mine rather than cheap supermarket fuel and that makes a noticeable difference. You could try some fuel system cleaner and change the fuel filter. There are lots of little things which will help with fuel economy.
  1. What Affects Torque?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2009, 09:59
  2. S3 MPG - what are you guys doing??
    By Irish in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2007, 17:02
  3. whats your mpg reading?...and whats the max youve had?
    By *Rashs3* in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 09:18
  4. 2.0T SLINE WHAT WOULD YOU EXPECT MPG?
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2006, 23:57
  5. What an average... (mpg)
    By wilko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2005, 06:56
Tags for this Thread
