EM TuningMonster Motorsport
    May 2012
    10
    Leaking Fuel Cap
    Hi,
    can anybody diagnose this problem? My A4 is leaking small amounts of diesel from the fuel filler cap. I replaced the cap with a genuine Audi cap but it has not solved the problem. The inside of the cap is always wet when I remove it (my previous cars were always dry) and there is a visible wet patch beneath the cap on the plastic surround by the drain hole. When I have fueled up this often spills out on the back wing, even when the tank is only half full!?
    Is this something to do with venting of the fuel tank? I spoke to my normal Audi specialist (not dealer) who said he had never come accross it before.
    I have done some searches but I cant see anyone with the same problem.
    Any help appreciated.
    Tim
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    mine does the same although ive never thought it was a problem till now, do they all do it?
    May 2012
    10
    Not sure but I've only noticed this on the last two fill ups. Can't be much fuel as it hasn't had any noticeable affect on mpg. Just don't fancy my hard earned diesel splatting down the back of my car.
    Do you notice it on the rear wing?
    Jun 2013
    I have the same problem on my A3. I noticed the fuel on the rear panel a couple of times then saw that the inner cap was sludged up. I cleared it out with a cocktail stick but it is still happening. When I wash the car water sits in the inside of the filler cap area and doesn't drain, which I don't think is correct.
    any ideas?
  1. Fuel cap - what do you do with yours?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2012, 18:52
  2. Locking fuel cap
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2010, 10:33
  3. Fuel Cap Tyre Pressures
    By Pinknoise in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th June 2009, 23:37
  4. Hissing fuel cap
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th January 2008, 13:04
  5. 1.8T - hissing from fuel cap?
    By niggtv in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2006, 09:53
