Results 1 to 19 of 19
    hitman1978's Avatar
    Apr 2012
    castleford
    101
    b5 spring perches?
    Hi, I spoke to my local tps today regarding prices for b5 spring perches, they claim there are 3 different versions and would need a chassis number or part number. Anyone any ideas to what perches I would need for an 03 sport Quattro, thanks
    A4 b6 1.8t 190 sport Quattro avant revo stage 1
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,722
    Re: b5 spring perches?
    As far as I'm aware they're all the same. I've never heard of different part numbers for them.
    hitman1978's Avatar
    Apr 2012
    castleford
    101
    That's what I thought aswell, bloke at tps has never heard of the mod either tho
    crazy88's Avatar
    West Yorkshire
    4,722
    I know yours is a 1.8T, but these are the part numbers i just used for my perches and they fit perfectly. Stoke Audi man never asked for engine, license plate etc so I assume they're a part for all engines and specs?
    b5 perches and pinch bolts for b6
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    Fitted mine a couple of months back and I ordered them from TPS,
    Here's the part number:
    8D0412103B
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    ^^^Got beaten to it ^^^
    hitman1978's Avatar
    Apr 2012
    castleford
    101
    Thanks to both of you, just need to sort some cash and some time to get these done
    Dec 2012
    Northants
    217
    £60?? Be jsut as much to just buy front lowering springs wont it?? Would save the hassle of pinch bolts too....
    If it's got tits or gears it's gonna be expensive.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    £60... mine cost me £36 + vat for the pair
    Dec 2012
    Northants
    217
    For the perches??? Crazys cost him £60 looking at the link
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    Yep for both perches from Cambridge TPS about 9 weeks ago
    Dec 2012
    Northants
    217
    Ahh right cool, interesting this as I'm thinking of doing it too, whats the deal with the pinch bolt tho? I've read it's a nightmare...
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    the pinch bolt is what secures both top arms to the hub carrier BUT you dont have to remove the bolt to gain access to the suspension leg, instead do everything as normal but leave the long pinch bolt alone and instead release the top suspension arms from the other ends and to do this you need to drop the suspension leg from the turret so you can access the other 2 bolts, doesn't take any longer to do it this way in fact it will likely save you time trying to remove the long pinch bolt.
    Dec 2012
    Northants
    217
    ahh right cool. Dont GSF sell the perches???
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    No idea Im afraid I only went to TPS
    Dec 2012
    Northants
    217
    Ok well I'll Give them a bell tomorrow. Dont suppose you've got a pic handy have you??
    dale86's Avatar
    Oct 2012
    307
    Great stuff this threads come just at the right time as ill be doing mine shortly too thanks for the info.
    hitman1978's Avatar
    Apr 2012
    castleford
    101
    I'm hoping I'm lucky with the pinch bolts, all my arms were replaced less then 6 months ago so hoping they'll come out no problems
    crazy88's Avatar
    West Yorkshire
    4,722
    I'd recommend trying to battle with the pinch bolt if you have time anyway, it's handy to come out as if you ever need to replace a control arm you'll need to remove it anyway. Once it's out just use anti-seize and if you're concerned for future wellfare then loosen it and remove it every year, it might help to stop the corrosion.
    As for the perches, yeah mine came to the best part of £60 (inc vat), but that's cos i also bought four replacement pinch bolts which were nearly a tenner. Plus, i was a bit lazy and stoke audi man delivered them to my door :D Chances are you'll need replacement bolts, especially if they're as horrendously corroded as mine were. They ended up in 4 bits in the end, due to both ends shearing off and then cutting them.
    And as above, whether it's lowering springs or perches...the springs need to come out as it's what the spring sits on.
