Chris NottJMB Retrofits
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By vr6gordy
Thread: I want to install puddle lights.......How?
    gonna getcha
    Dec 2006
    somewhere where the the speed limit is over 150mph.
    72
    I forgot to mention as above i want to fit puddle lights. How do you do it and what do you need? Neil
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    T0m
    Sep 2007
    Lichfield
    453
    Its a pain I also wanted to do this but the work to get to the convenience module is a right mare i stuck with just the red warning lights in the doors and puddle lights thanks to Robin in the A3 forum!!!
    Mar 2008
    1,040
    If you got red marker lights already its so easy ...all you need is a clear light a sharp knife a bit of wire and a bit of welding wire ... First cut the hole out found under your door card with the sharp knife then pop out the red light at the side of your door card .. Then push the welding wire in the hole and feed it in so it pokes out the hole you have just cut then tape 2 bits of wire to it (live and earth) then join to the wire that powers the red light on your door .... Easy and you don't even have to remove your door card
    crazy88 likes this.
    kevbu's Avatar
    Aug 2010
    59
    Halfords | Prism LED Puddle Lights
    Ive had a set of these knocking about in a drawer for ages, if it's as easy as you say Gordy I really should get them on!
    I want them under door not on mirrors, wonder if there is enough clearance?
    Mar 2008
    1,040
    Quote Originally Posted by kevbu View Post
    go to scrap yard look out for a passat ...look at bottom of doors and you will see the proper lights you need you could even rob the wire as your there then all you need if you want led lights is the bulbs .. So cheap on eBay you get about ten for the price of one in halfolds
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    218
    As said above, scrappy is your best bet, I got about 10 puddle lights and door markers for 50p! Then made my own loom and wired into the factory socket and all works well
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    T0m
    Sep 2007
    Lichfield
    453
    What am I on about I just realised I was in about the footwell lights puddle lights are as per the above instructions they look good just wish the footwell ones were as easy!!!
