Badger5AH Fabrications
Like Tree2Likes
  • 1 Post By a6-chris
  • 1 Post By stu_m
Thread: Confused Please Help!
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    I have just replaced my alternator (2.5 v6) what a nightmare, finally put car back together and runs fine but central locking doesnt work at all,
    Car locks and unlocks with door lock,
    Is this because i had the battery disconnected for 2 days (had to wait for right alternator to be delivered)
    How do i go about making it work again?
    Also done a service whilst changing alternator, Only problem is now how do i delete the word "service" from dash display?
    Regards
    Jamie
    Jan 2012
    1,837
    there should be a resyncing procedure in your manual but from memory it goes something like this -
    turn the ignition on
    hold in the lock button on the keyfob
    turn ignition off
    close door and press lock on the key
    could be right, could be wrong but only going from memory and reading similar posts .. re the service, again it should tell you in your manual but if you do a google search for "b6 service reset" or something similar you should find results.
    Jamie1985 likes this.
    Oct 2009
    Hull
    1,442
    its because you have had the battery off
    insert the key turn the ignition on dont start it press lock then unlock on the fob and all should work
    to remove the service press and hold the service button (spanner) then turn on the ignition then hit the 00 next to the service button and it will reset it...it will take a few days before it starts counting down again
    your one touch windows will have stopped too you need to press and hold the button down and keep it down for a few seconds after the window has dropped then back up again and hold the button up for a few seconds then they should work fine
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Brilliant help guys much appreciated, didnt realise windows wouldnt work, all sorted now, untill something else pops up!
  1. Head unit confusion please help
    By Pbowers1979 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2012, 10:12
  2. Purchase confusion, please help
    By Hightower in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2009, 08:38
  3. Purchase confusion, please help
    By Hightower in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2009, 21:03
  4. Please help, im seriously confused!
    By Seedler in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2009, 12:10
  5. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
