Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Mar 2012
    163
    Are b6 saloon/avant/cabriolet headlights all the same?
    As per title really guys, are they all the same?
    Mine are full of condensation and want to change them, have found a good set from a a4 b6 cabriolet, will thy fit?
    Töm's Avatar
    Jan 2007
    42
    Saloon and Avant are the same but Cab are different
    Mar 2012
    163
    Damn, will they not fit then?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,536
    cab are for cab only
    Mar 2012
    163
    Ok cheers, that's ashame!
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    instead of new lights try taking the black cover off that clamps onto the back of the light, that will allow the water vapour to escape when they warm up
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    Mar 2008
    1,058
    remove your old headlights from car .. then remove the bulb cover the get hair dryier and get hot air in the light unit this will dry out your headlights then get some stikaflek and and seal the covers back on the lights and where the plastic lense meets the unit put a little on there and rub it in the grove around the unit .. also the other place where they leak is where the wires plug in to the light unit .. again run i little beed around there to seal them up
  1. Are 3dr and 5dr parcel shelves the same
    By Lings in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2011, 19:44
  2. Facelift A3 & S3 Headlights the same ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2009, 01:01
  3. Are A4 headlights the same as A3?
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2009, 17:04
  4. A4 seats saloon / avant / cabriolet???
    By cocain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th May 2008, 20:55
  5. does a 2002 Cabriolet have the same pcd as a 2002 A4?
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2005, 12:35
