Sky InsuranceJMB Retrofits
    gonna getcha
    Dec 2006
    somewhere where the the speed limit is over 150mph.
    72
    Service Requirement. Help
    Booking the car in for service, Lost my service book in the house somewhere. Just wondering what is the service for a 2004 a4 1.8 turbo? What parts will be replaced? Any ideas or look in a service book to let me know! Cheers Neil.
    Southampton
    159
    Dont know what previous work you've had done but if you're booking in for a service id get.... Fully synthetic oil and filter replaced (make sure its fully synthetic) air filter and spark plugs. That will do for starters but you can throw in fuel and pollen filter too if you're feeling flush!
    Oct 2009
    Hull
    1,442
    as above but has the cam belt been done?
    Jul 2012
    Derbyshire
    306
    Mine is a 1.8t on 74k when it gets to 76 it's havin all filters oil and timing belt and water pump done been quoted £450 last service was only at 70k but wanna get this one out the way for piece of mind the belts been done
    Southampton
    159
    Yeah, cambelts the biggie. Once thats done just need to keep on top of the oil changes, the rest can be done at you're convenience
    T0m
    Sep 2007
    Lichfield
    458
    Fella Audi do a minor service (oil and filter) and a major (oil/filter, Air/Pollen filters and spark plugs) they alternate these two then Id have the cambelt done along with the pully and tensioners and water pump if you can at the same time at 60/70k or 5 miles which ever comes first.
    If you can do the service yourself you will save a good chunk of money!
  1. Service Costs - Help Needed
    By dobber in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2009, 12:48
  2. Service Reset Help via Vagcom
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2008, 21:51
  3. TYRE Recommendation Required - HELP
    By ZACK in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2008, 21:16
  4. service indicator help pls
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2007, 18:49
  5. Independent servicing required in Cornwall
    By SimonA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th August 2004, 22:39
