Service Requirement. Help
Dont know what previous work you've had done but if you're booking in for a service id get.... Fully synthetic oil and filter replaced (make sure its fully synthetic) air filter and spark plugs. That will do for starters but you can throw in fuel and pollen filter too if you're feeling flush!
as above but has the cam belt been done?
Mine is a 1.8t on 74k when it gets to 76 it's havin all filters oil and timing belt and water pump done been quoted £450 last service was only at 70k but wanna get this one out the way for piece of mind the belts been done
Yeah, cambelts the biggie. Once thats done just need to keep on top of the oil changes, the rest can be done at you're convenience
Fella Audi do a minor service (oil and filter) and a major (oil/filter, Air/Pollen filters and spark plugs) they alternate these two then Id have the cambelt done along with the pully and tensioners and water pump if you can at the same time at 60/70k or 5 miles which ever comes first.
If you can do the service yourself you will save a good chunk of money!
