JMB RetrofitsAH Fabrications
    Oct 2012
    Stanley, County Durham
    151
    Cabriolet window switch
    Hi all, another day, another problem!
    noticed today that the switch for the rear passenger window doesn't seem to do anything when pressed. On a cabriolet you have a bank of 5 switches on the driver door; driver window, from passenger window, rear driver side window, rear passenger side window, and then "all". The "all" button makes the window go up and down, so I'm happy that the window motor etc works, it's just the specific button for that window doesn't seem to work.
    can anyone suggest a fix please?
    cheers
    Paul
    Mar 2011
    S E Kent
    238
    Could it be a bad or non exitant connection under the switch?
    Does the switch light up?
    2006 A4 cab
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Paul you need to get some electrical contact cleaner, the aerosol type with the small straw. I found the only way that worked on mine was to remove the window switches from the door, dead easy there's a tiny hole under the door handle , you poke a small screwdriver in the hole and the window switches just push out. Then disconnect the wiring so the switch unit is removed. Then spray the contact cleaner in all the holes you can whilst working the switches,I think I un-clipped the tabs on the switch unit to split it down some more but I had several buttons not working. Make sure you get plenty of cleaner in there to properly clean the switch contacts, should turn out good as new. Robbie.
    2004 A4 Sport Cabriolet 3.0
    Oct 2012
    151
    Thanks for the help! Rudedaubin, would I get the contact cleaner from halfords or is there somewhere else I should be looking?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Yes, Halfords do it.
  1. Window Switch
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2009, 20:26
  2. Audi Window Switch 8L0 959 851
    Last Post: 14th February 2009, 13:11
  3. drivers side elec window switch removal
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2008, 20:29
  4. A4 Cabriolet - Window rattle..help...
    By goodhixy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th January 2008, 17:10
  5. A4 (96) leccy window switch....
    By twistie in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd November 2004, 10:36
