Chris NottMonster Motorsport
Results 1 to 11 of 11
    Dec 2012
    47
    B6 How to adjust headlights aim?
    Hi, I have one headlight pointing at a strange angle upwards. Also only the small round lights are on for low beam, and the big main headlights come on for main beam. Is that normal? How do I adjust the main headlight aim? Is there a load sensor to fiddle with too?
    Thanks!
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,727
    There's a couple of screws on the headlight unit, I believe they are white. Turn them and they will move up or down. Best bet is to get it taken to a garage though as they'll have one of those proper lens alignment jobbies to make sure you get it done. If you smile and giggle at him you might get it for free :D
    Dec 2012
    47
    Ok thanks...does this mean it doesn't have any lineages or load sensors on the front or rear suspension?
    crazy88's Avatar
    West Yorkshire
    4,727
    If you have HID's as standard it will auto-level. If not, then you'll have to manually adjust them. There is the standard up-down settings from the knob next to the headlights, but proper adjustment is done at the headlights, under the bonnet.
    Dec 2012
    47
    OK bit the problem is, it's not auto levelling....It's way out of alignment. Seems a bit strange to have to adjust it from at the light so much, so for that I was wondering if there's a load sensor that might be out.
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    I think the load sensors depend on whether you have auto levelling or not, there's 2 black plastic allen key adjusters on mine on top of the headlight, one is accesed through a hole in the top of the wing above the indicator and one above the main beam. It is a cabriolet though so maybe different if your a saloon/avant.
    2004 A4 Sport Cabriolet 3.0
    Dec 2012
    47
    the nearside light points at the sky!
    Dec 2012
    47
    OK thanks, I'll have a look. Cheers for replying, JJ
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,722
    Sometimes the remote levelling motor mechanism can become detached, and the reflector inside will wobble about loosely.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,418
    Just take to an mot garage. Over the years i sometime get it done for free or charged £10
    Mike
    Dec 2012
    47
    Thanks! Just the sort of advice I need. I'll check that out. Best wishes
  1. Headlight Aim
    By S3DBW in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th March 2008, 17:07
  2. headlight aim
    By mastayoda in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2007, 18:41
  3. Headlight aim -A4 (b6)
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st August 2007, 15:26
  4. How to clean headlight washers??
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th September 2006, 00:22
  5. Headlight aiming (non-Xenon)
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 18:04
Tags for this Thread
