Monster MotorsportChris Nott
Results 1 to 10 of 10
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Exclamation Need Help Guys + Girls
    The battery light came on yesterday was going to sort it saturday when i have time,
    Today tho on the way home the ABS light and Traction control lights came on aswell cant turn them off using the button!
    When i go to put my foot down it pulls away but seems to be holding back
    Please help
    Many thanks
    Jamie
    Sep 2011
    hi there
    are your brake lights working? if not have a look at the brake light switch, this can bring the traction and abs lights on
    i had this issue myself and it was a faulty brake light switch
    hope this helps
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Hi thanks for the response, On the on board computer screen it did have a bulb with a line through it and i think it said centre brake light out (not too sure)
    Just spoken to a mechanic he said it sounds like an alternator issue?!!
    If so is this a big job?
    Sep 2011
    i shouldnt imagine so as they are easy enough to work on labour wise
    not too sure on price of alternator tho
    hope you get sorted
    Jun 2010
    East Manchester In the Hills !
    597
    Alternator not too bad. Just awkward. Brake light switch is a 5 min job and only about 20 quid. Do this first. I had same issue on a golf and it just killed the power. Took the switch out and it had melted !
    Oct 2009
    Hull
    1,433
    you can easily check to see if your alternator is working if you have a multimeter
    start the car put it across the battery terminals and you should get a reading of around 14 volts
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Car wont start Stu so cant check, car was running then faults appeared and i turned it off and it acts like batterys dead (wont turn over, no power)
    Oct 2009
    Hull
    1,433
    sounds like the battery is flat to me which could be alternator not charging
    all the other lights could be related
    get the battery charged or try jumping it from another car
    its no good trying anything with a flat battery
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    the battery will have flattened if the alternator is dead.
    Sep 2009
    Rumburgh Suffolk
    175
    As mentioned if the brake lights are stuck on due to a faulty switch the battery will drain also. The brake lights work even if the ign is off..
    If you try to accelerate with the brakes on (or the brake lights stuck on) the car will restrict power to protect itself...
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
  1. Need help guys.
    By Jonny 2.0T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2012, 19:32
  2. How much is my car worth - need your help guys!
    By gtiglasgow in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2007, 17:04
  3. need help guys
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2007, 17:27
  4. exhaust pics need some help guys
    By tracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 16:28
  5. 2000 A4 1.8l bucking like mad...new guy needs help
    By cyrjm in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st November 2004, 21:40
