Badger5Monster Motorsport
Results 1 to 12 of 12
    Sep 2005
    UK
    91
    brake pad thickness
    Does anyone know what the minimum thickness of brake pads should be on an A4? easy to view with the 5 arm wheel.
    FrankG's Avatar
    Ireland
    160
    Re: brake pad thickness
    They will go down to roughly 3-4mm but if you have a B6 model a light will come on to let you know they need replacing, I even drove mine for a further 3000 miles after the light came on and there was still some pad left.
    Sep 2005
    UK
    91
    Thanks for that Frank
    scoTTy's Avatar
    Essex, UK
    1,958
    The minimum thickness is 0mm but it's not recommended!!!
    My light came on and within 30 mins I was metal on metal....at Snetterton.
    Jun 2004
    Surrey
    194
    Mine are being replaced tomorrow at AMD for EBC pads. The originals have lasted 34000 miles and are at around 3 to 4mm.
    Was going for EBC discs but apparently none for the rear.
    scoTTy's Avatar
    Essex, UK
    1,958
    If you managed to make your OEM pads last 34k miles then do you really need after market pads and disks?
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    When I had my car serviced at 48000miles they said I'd probably need new pads on the front before my next service. I'm on 53000miles now and still no warning light - original pads [img]/ubbthreads/images/graemlins/cool.gif[/img]
    Jun 2004
    Surrey
    194
    scoTTy
    A friend of mine had OEM pads on his TT for good miles but then had EBC from AMD and said they performed better, lasted longer and gave off significantly less dust onto the alloys. And they are cheaper!
    scoTTy's Avatar
    Essex, UK
    1,958
    Pads I can understand due to the cost and less dust but disks?
    Jun 2004
    Surrey
    194
    I only considered the disks because AMD suggested checking them. I would have gone for EBC rather than OEM. As it happens I'm at AMD at the moment and the disks are fine so just pads.
    Don't know if you guys have been to AMD recently bu they have expanded into another unit with big reception, massage reclining chairs and Monaco GP and Turbo Outrun arcade machines. A couple of old classics!
    scoTTy's Avatar
    Essex, UK
    1,958
    Worth checking. I just couldn't see why you'd want to spend a load of cash on after market brake disks when it would appear that you're fairly light on the brakes.
    AMD reception is much better since the old one..not least the WiFi. [img]/ubbthreads/images/graemlins/ok.gif[/img]
    Jun 2004
    Surrey
    194
    Thr only strange thing about these pads is the wedge shape. The pad doesn't sit flat to the disk. And the front pads are a lot thicker.
    And as for the colour....!
    As long as they work. I have been very light on the pedal on the way home but have heard some brake squealing. Hope that is normal to start with.
    And finally i only managed 3rd on Monaco GP. But took me back a few years.
