EM TuningMonster Motorsport
Results 1 to 11 of 11
Thread: Squeaky wiper
    Oct 2012
    Stanley, County Durham
    148
    Squeaky wiper
    Hi All, tried doing a search but couldn't find anything specific to the B6. I get an annoying squeak from the drivers side wiper every time it wipes. It's not the blade on the glass, seems to be the pivot point that its coming from. Has anyone else had this problem, and if so how did you fix it? Is it just a case of putting some WD40 on it, or is there more to it?
    Thanks for any help
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,695
    Squeaky wiper
    Is it the start of the slow wiper problem?
    Oct 2012
    148
    Hi QJ,
    Not in the know enough to know the answerer unfortunately. It has done it pretty much since i got the car a few months back, but they seem to wipe at a normal speed. Can you elaborate please?
    Cheers,
    Paul
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Squeaky wiper
    Basically m8 its the start of bad news were the wiper mechanism is seizing up in the unit itself you can strip it down and sand it down and degrease it if your clever with the tools....
    It's the spindle itself inside the unit that needs re cleaning out.....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2012
    148
    Ar5e - does anyone have any link to a DIY guide for fixing, or an estimate of the £ damage I should expect if I took it to a garage?
    T0m
    Sep 2007
    Lichfield
    452
    Knew that would be coming here is a link to one guide its for a left hooker but it helped me AudiWorld Tech Articles
    Oct 2012
    148
    Cheers mate, thats really helpful
    Mar 2008
    Dorset
    13,695
    It's not a difficult job in honesty. My guide is here:
    Slow wiper mechanism repair
    Oct 2012
    148
    Thanks QJ, that's great! As ever you are a fountain of knowledge! Just reading through the other thread you linked to, a few people suggest using 3in1 spray as preventative short term fix? I'm going on holiday for 2 weeks this weekend so the car will be parked up for 2 weeks, I don't want to get back to my car at Manchester airport and have seized up wipers! Do you know if the 3 in 1 spray helps? Any idea where to spray it if so? I presume just pop the caps off the end of the spindles and spray in?
    thanks very much for you help
    Mar 2008
    Dorset
    13,695
    No, you'll need to take the plenum cover off if you have one, and spray it into the pivot points of the wiper mechanism. Not the little knuckle joints, but the bit where the spindle rotates in the frame. It's probably worth spraying a water repellent in there to keep the water out. It's very much a short term solution though, and try and use the spray with the little red tube so you can aim it in there ok.
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    521
    The guide is excellent, I followed it and my wipers are still (over a year later) going really well. I used LOADS of copper grease!
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
  1. Squeaky Aero wipers
    By Block 405 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd November 2006, 14:56
  2. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  3. New A3 Kaput Wipers
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2004, 22:12
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
