Sky InsuranceChris Nott
    Oct 2012
    385
    Avant radio reception with heated rear window on was rubbish now solved
    Nice to report an easy fix for a change, we had been suffering from non existent radio reception when the heated rear screen was on,turns out i had 2 small breaks in different lines, a touch in using comma electrocure good as new.
    kevbu's Avatar
    Aug 2010
    55
    Sounds promising, I have same problem, yours is an avant too? Where were the breaks, rear screen or aerial (side) screen?
    Oct 2012
    385
    The breaks were on the rear screen, first one high up in fact underneath the rear window sticker and the second right hand side half way, and yes on an avant
  1. Heated rear window interferes with radio reception
    By ADi Nuff Valves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2011, 22:12
  2. Cleaning Heated Rear window
    By rasA4 in forum Detailing
    Last Post: 24th August 2009, 10:35
  3. Heated rear window interferes with radio - B5
    By JAM35F in forum In-Car Entertainment
    Last Post: 4th September 2008, 21:42
  4. Heated rear window interferes with radio
    By JAM35F in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2008, 08:37
  5. HELP!! Heated rear window and wing mirror problem
    By tboy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th November 2004, 14:14
