Volks AutosChris Nott
Results 1 to 12 of 12
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    cruise control, how do i use it?
    My car has the stork but im beginning to think its not connected or programed? No amount of fiddling with it seems to do anything lol i might be being daft and it might be simple but i cant do it haha
    Jan 2012
    1,837
    You may have a faulty clutch or brake switch.
    A scan with vcds would show this.
    Oct 2009
    Hull
    1,442
    Re: cruise control, how do i use it?
    A scan does not show a faulty clutch switch you would have to look through measuring blocks to check
    To operate the cruise you have to have the stalk in the on position which is pulled towards you you will feel it click in then you get to a speed above 20mph then push the center button
    If it doesn't work then you have a problem which is more then likely the clutch switch
    If you can't get it scanned then remove the trim which covers the area where the switch is remove the plug from the switch and short the plug with a piece of wire and try the cruise again if it works you need a new switch at around 15 quid
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,580
    That or it was retro fitted and never programmed into the car
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Ok cheers lads i will try linking the switch out today
    beachbuggy's Avatar
    Surrey
    1,746
    Or it was retro fitted and the control module wasn't changed and its a F version. Again a scan will tell you.
    Oct 2009
    Hull
    1,442
    Yes it could be that its not been coded but if you don't have vcds its far quicker and cheaper to check the clutch switch
    Check one thing at a time if shorting the clutch switch doesn't work then get it plugged in and checked it could even be a duff stalk
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    How wud i get it scanned? Im guessing not every obd scanner can go so deep into the programms. Is it just average joes with the software on their laptop?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    I could take a look for you. I have VCDS and am in Ashington.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Al send you a pm if it comes to it mate, cheers
    Oct 2012
    Stanley, County Durham
    151
    Small world! We're abouts are you ollie?
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Just down from asda mate
  1. How to install cruise control Audi A3 8L
    By Frederik in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2013, 08:47
  2. Cruise Control Fitting - How easy to fit actual parts - advice needed
    By Custardsucker in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th April 2011, 18:17
  3. How To:=- Cruise Control
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2011, 10:53
  4. Replies: 4
    Last Post: 29th January 2010, 11:49
  5. Cruise control *** How do I fit ***
    By imported_Coullio in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2005, 20:34
