AH FabricationsVolks Autos
Results 1 to 11 of 11
    Oct 2009
    Hull
    1,442
    Any battery experts?
    So over the past few months I have been getting the brake warning on start up and as we all know it suggests battery is on the way out so checked it and sure enough its only getting up to roughly 75% charged
    anyway I went and picked up a new bosch battery today from euro car parts got home and the first thing I did was check the charge state!
    to my horror its showing 10.6 volts!!!
    Am I right in thinking batteries should come already charged and must be kept charged and if the voltage drops below 12.3 then it needs to be charged otherwise permanent damage can be caused and the life expectancy reduced?
    I have searched online and found nothing about if they should be supplied fully charged etc
    Any advice welcome
    Inertiauk's Avatar
    Mar 2011
    529
    I'm not an expert but I had one sat in my garage which was fully charged but ended up flat as can be reading 10v after about 6 months, my mate stuck it on charge overnight, put it in his car and it has been fine ever since.
    When I got this fault the same on my car I changed the battery (it was about 75% chargeable according to a garage who tested it) This never cured it, I needed a new fluid reservoir to cure it.
    This is the battery mentioned above, I kept my new one and sold the old one to a mate.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,157
    Sounds like an alternator/drain issue to me.
    Batteries do come charged, I would expect a new battery to show above 12/13v even after 5 minutes charge.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Dec 2012
    36
    put a voltmeter across the battery to see if its chargeing whilst the engine is running? and check voltage when cracking see what it dropes down to? if not i would say you've got problem poss alternator or wireing fault check connection and earth points on loom to alternator
    Dec 2012
    36
    meant cranking
    Oct 2009
    Hull
    1,442
    Re: Any battery experts?
    Err think you need to re read!
    My old battery is only taking 75% charge so I have got a new one
    The new one has come straight from the shop with no charge and showing 10 volts! The new one has not been on the car
    The question I'm asking is can damage have been done with the new battery stored with only 10 volts?
    I don't want to mess about charging it if damage could have been already done because as far as I'm aware you have to keep battery's charged
    Feb 2012
    Liverpool
    1,157
    I wouldn't have said so. Batteries only really get damaged if overcharged/hot.
    If you charge it for 5 minutes or so it should jump straight to 13/14 volts. If charged for an hour or so it should hold 13/14 volts for a few days.
    - Weitec GT
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    I don,t profess to be an expert, but from previous experience batteries only suffer permanent damage if they're left to run totally flat or the electrolyte is low! give it an 8 hour top-up charge, check the voltage again and if the alternator isn't the culprit, it should be fine. Once it's in the car with the engine running, it should how around 14 volts, if the Alts doing its job.
    2009 A3 SB 2.0T DSG S line
    Oct 2009
    Hull
    1,442
    I've known batteries go bad and still show 12 volts
    I know your not suppose to discharge a battery as it can kill them I know as I have had it on a bike
    I don't want to start charging a battery that could already be shafted and a year down the line drop a cell and leave us stranded!
    Ok it has a 5 year warranty but that's not the point I don't pay 70 quid for something that could already be damaged
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    I wonder if someone as already fitted it who had a alternator fault, but then found the alternator fault afterwards and then taken battery back for a refund ?? Just an idea....
    The other thing is if the battery as been sat on a cold concrete floor that will probably zap the battery voltage a small amount..... But you would expect to buy a lively new battery that you fit in confidence..... Take it back and show them....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2009
    Hull
    1,442
    It's not been fitted before there is no marks at all on the terminals
    I can't work out where the date code is on it either so don't even know how old it is
    For a battery to lose that much charge it would take about 6 months maybe more
    I have found a bit of info which states if a battery has been discharged slowly to lower then 11.5 volts then permanent damage will be done so on that basis I shall be taking it back
    And just to point out for future reference if you discharge a battery fast then recharge it then no damage will be done
  1. Any MOT experts ?
    By scottie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 23:29
  2. For any wheels experts out there please!...
    By Audime in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st August 2009, 00:11
  3. Any bumper experts?
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2009, 09:09
  4. Any VW experts?
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2007, 21:35
  5. Any photoshop experts out there?
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2004, 13:36
