JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Dec 2012
    Reading
    Very rough idle and emission light on 2.0 FSI
    Hi the other day my 03' 2.0 FSI A4 starting quite violently shaking when i was parked idling, it only does it under 1000 rpm soon as i press the accelerator the vibration stops, just quite worrying when i stop at lights etc,etc. Also the day after waht i thought was the engine management light came on, however after consulting the handbook realised its the exhaust/emissions light. Havent had time to take it to the garage yet and done about 600 miles since i noticed it with no ill effects....
    Anyone got any ideas as to what could be causing either of the problems? Id like to think theyre linked?
    Thanks in advance for any suggestions.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    id go for coilpack's
    but it realy needs pluging in to get the fault codes.
    chrisa4quat's Avatar
    Sep 2004
    897
    Is it a misfire?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Dec 2012
    Reading
    Not sure, its only when the engine is warm and sitting at 800 revs,just feels like the engines rocking almost? As soon as i touch the accelerator or whilst driving its completely fine?
    bez101's Avatar
    Jul 2008
    8,492
    as above you need a scan for codes
    but i do think its a mis from the coilpacks.
    Sep 2004
    897
    Could be an air leak. Misfire should be present all the time
    B6Steve's Avatar
    Feb 2012
    NI
    42
    Lift the cover off the top of the engine and check the oil breather hoses, very comon to have a split there where it plugs into the rocker cover where the pipe dissappears into the inlet manifold.
  1. How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th May 2011, 18:57
  2. Emissions Light and Exhaust Gas
    By aadams1x in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2010, 22:04
  3. Emissions light!! and Value?
    By suthers in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th January 2009, 11:12
  4. Rough idle and slight backfire!!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2008, 15:22
  5. Car spluttering and Emissions light on
    By Alex2.0T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2007, 09:18
