EM TuningJMB Retrofits
Results 1 to 8 of 8
    Dec 2012
    47
    Shaking Stevens when I depress clutch!
    Hi, my 1.9 tdi a4 b6 shakes from side to side....as if someones outside pushing it from side to side but only when i press the clutch at tickover. When i release the clutch the shaking stops. It also has a slight rattling sound from the engine when it starts up in the morning (more than the normal diesel noise)....it's as if something metal is loose in the engine, but when it's warm it doesn't do it. It drives fine, no clutch judder or slip. I can feel a slight vibration through the accelerator though. Any help please? Thanks
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Sounds like a worn engine or transmission mount. What's the mileage?
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Sounds like the beginnings of a DMF failure to me,
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Dec 2012
    47
    How long can the DMF last if it's like this?
    Dec 2012
    47
    Thanks for the suggestions!
    Steve B5 Biker's Avatar
    Jan 2012
    SOUTH YORKSHIRE
    129
    My dmf been giving me clutch judder for six moths, but only does it when engine gets hot and i do any slow manouvering/clutch work.
    New clutch and single flywheel conversion sat in box in dining room waiting to be done in the new year...
    Dec 2012
    47
    Will you do it yourself? Is it an easy job?
    Jan 2012
    SOUTH YORKSHIRE
    129
    Not much good with spanners afraid, but i have a couple of good mechanics on hand when i decide to do it, the cost of clutch flywheel was £360 but thats only because girlfriend is in the trade and ive got it at cost,
    just as a guide the stealers wanted nearly 1k not inc fitting...
  1. Slight increase in revs when changing gear. Clutch pedal sensor?
    By jackpilk in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2012, 18:48
  2. Bushes to replace when getting S3 clutch changed
    By essIII in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2012, 09:22
  3. Grinding noise when pulling off? (clutch releasing)
    By Herbsta1c in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2011, 09:21
  4. Car shakes/wobbles when stationery
    By Harrelson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd July 2011, 16:08
  5. Clonking noise when engaging/disengaging clutch
    By Jay88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2010, 05:03
