EM TuningJMB Retrofits
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By rjm180
Thread: RNS-e to replace standard radio
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    Is there anybody on here who will do this (supply and fit the parts) obviously for a cost? I have just bought an a4 as ive just had a child and the m3 wanst very child friendly and ive seen these get retro fitted but i just dont have the time to do it, thanks for any help
    Jan 2012
    1,837
    Depends whereabouts you are?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    Hi, welcome to audi-sport.net. Where are you located? Nigel (user NHN) supplies and fits rnse, he has a great reputation and his work is 1st class. He does travel to do this kind of work, but it depends on your location. Send him a pm and he will discuss with you. Enjoy the forum. x
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Sorry i maybe shud of said, im from the north east, newcastle way. Thanks alot i will pm him
    Mar 2009
    470
    I can highly recommend NHN ( Nigel ), he has done some work on my S4 recently including fiiting rnse, if he doesnt reply to your pm straight away its because he could be off line for xmas and new year but as soon as he's back im sure he'll reply asap. First class job.
    Ollie-B likes this.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    224
    Do you have a single or double din radio in the car? If you have a double din radio already the RNS-E will be plug and play and can be fitted in 5 minutes. If single din parts needed will be a double din cage, new climate control unit (or cut the single din one down to fit in the lower position) a new center console or trim your single din one as well, a RNS-E wiring kit, an RNS-E and about 2-3 hours to change it all over. Its not that hard to replace it all, i cut all my bits and looks fine. I was lucky and got all my bits cheap including the RNS-E and managed to do it all for £160
    You need to be confident with stripping you interior as it can be abit scary when you reach this stage!
    But its an achievement when done.
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I would be more than capable to do it myself, was only asking for outside help because i have no idea what parts to use or how to code it in to the cluster, my radio is the concert 2 according to the face of it, just a single one with cd slot. If i could get the parts for that price i would have it fitted tomorrow lol ive only seen the unit for a good few hundred never mind the rest of the stuff i need
    VagCabby's Avatar
    Apr 2012
    224
    I think the cheapest I have seen an RNS-E for is around £400. I bought mine from a member on here for £130 as it wasn't reading DVDs for the satnav but I managed to get it working. The cage is £45 from Audi or can sometimes get them cheaper on eBay and the harness is around £10 on ebay. Obviously if you don't cut the climate panel and you buy a new one there around £100+. Was lucky as mine was out a cabriolet with the same features as mine so it didn't need any coding.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    I will be trimming my climate pannel down if its possible. So all i need is the double cage, rnse unit and the wiring adapter? Then get it coded yes?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by Ollie-B View Post
    You'll also need a GPS hockey puck antenna, and an antenna adapter too - the RNS-E has a double Fakra for the antenna inputs.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    There is a kit i seen on ebay for 30 that has everything you need (apparently) except the double cage and the rnse itself, it has the wiring adapters, antenna, jeys for removing the radio and sure it said summit else i dont rememba what lol is it essential to get it coded once fitted?
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    VagCabby's Avatar
    Apr 2012
    224
    yup thats everything you need wiring wise, then all you need is the cage from audi and an RNS-E and your good to go. As for coding, i think it needs coding when fitted to different cars whih have different spec, for example having nav show up on your DIS and if you have a MFSW and CD changer etc you need to code the RNS to recodnise these things, it could just work straight away if your lucky like i was
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Thanks for your help lads, feel fairly good about rattling this off now, just need to find a cheap rnse cos am i balls payin 600 for one lol
  1. RNS-E Screen Replacement
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th October 2008, 17:50
  2. Replacing Standard Sub in a4 b6 tdi
    By JimmyT in forum In-Car Entertainment
    Last Post: 1st October 2008, 20:54
  3. Fasia replacement changing radio / headunit 2002 S3
    By davebirl in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2006, 17:10
  4. Fasia replacement changing radio / headunit 2002 S3
    By davebirl in forum In-Car Entertainment
    Last Post: 14th December 2006, 17:19
  5. Decent fascias when replacing standard radio/cass
    By mdoyle69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 17:45
