Sky InsuranceVolks Autos
    Apr 2010
    164
    difficult reverse selection
    Starting to find it difficult to engage reverse gear.Is there any adjustment to be made.Car is B6 avant 130 se.
    Sep 2009
    Rumburgh Suffolk
    193
    Do you find it difficult to engage 1st also when stationary, does it grind when you try to select reverse?
    During the cold weather its not uncommon to have difficulty engaging gears on a lot on manual gearboxes, usually 1st, then 1st to 2nd, just due to the gearbox oil being cold.
    If it does grind on reverse and doesn't want 1st either the clutch could well be dragging (not fully disengaging), best to get that sorted asap as it will put unnecessary stress on the syncromeshes
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Oct 2009
    Hull
    1,442
    mines always a bit notchy when its cold sometimes hard to go in to gear too once warm its fine
    Sep 2009
    Rumburgh Suffolk
    193
    Quote Originally Posted by stu_m View Post
    Same here, on my Cobra I used Castrol SMX-S in its gearbox, made a hell of a difference... 1970's british technology there though, not quite on ze germans level..
    Mark
  1. Difficult gear selection - clutch fluid time?
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2011, 19:17
  2. Continuous tone when reverse selected.
    By ragebe in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th July 2010, 13:33
  3. Difficult to select 1st gear, when starting. B7
    By ADR14N in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 15th February 2009, 12:29
  4. why does my car go forward when I select reverse???!!!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2007, 02:22
  5. Trouble selecting reverse.
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2006, 16:13
