AH FabricationsChris Nott
Results 1 to 8 of 8
    Dec 2012
    47
    What is this part called on audi A4 1.9 tdi 130, B6?
    I've noticed a pair of wires that go to some kind of sensor on the fuel line. The sensor looks a bit like a coolant temp sensor, but it's not as it's on the fuel line and only has 2 wires.....Any ideas? It looks like someone has tried to pull it off and has ripped the wires out instead and then stuck them back in with duck tape!!!! It's located on the top of the engine, just next to the fuel filter. Any help is much appreciated, thanks!
    19scotty81's Avatar
    Push down and across !!!!!!!!!
    Dec 2010
    Newcastle Upon Tyne
    107
    Photo ????????
    2004 A4 Avant
    Akoya Silver | 2 Graco Car Seats | Buggy In Boot |
    chrisa4quat's Avatar
    Sep 2004
    897
    Fuel temp or pressure I guess
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    Its the fuel temp sensor and it's held in the fuel pipe with a little plastic horse shoe shaped clip
    Apr 2012
    202
    Sounds like the fuel temp sensor there should be a part number on the plug which if you go to your local dealer should be able to get you a replacement and you'll need a repair wire too which comes with a connector each end so just snip it in half and attach one end to each damaged wire to fix.
    Dec 2012
    47
    Thanks Guys!
    Quote Originally Posted by Ian-83 View Post
    Thanks for the help. That's exactly what I needed to know! Could this temp sensor cause the mpg to be poor???
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Re: What is this part called on audi A4 1.9 tdi 130, B6?
    Yeah, it could
    Dec 2012
    47
    Ok, I'll get on and sort that as only getting 44 mpg and normally would be at 50 mpg....I've changed the coolant temp sensor and thermostat recently and that got the temp guage working again, but the mpg is still poor. Could it be anything else? Brakes and tyres are fine, recently serviced, etc.
  1. whats this part called?
    By tdisline170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2012, 11:45
  2. What is this wheel called?
    By darkfibre in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2010, 19:19
  3. what is this part????
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2008, 19:34
  4. what is this part making the noise - pics inside
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2007, 17:02
  5. Audi S3 - What is this part in these photos?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2006, 11:52
Tags for this Thread
