EM TuningSky Insurance
Thread: A few issues...
    Dec 2012
    21
    A few issues...
    Hi guys,
    I've recently bought a '53 Audi A4 Avant SE but noticed a few problems since I've got it home..
    Firstly, the drivers footwell carpet is soaking wet?
    Secondly, the lights in the boot don't work?
    Thirdly, the boot doesn't unlock with the remote key?
    Fourthy, the glove box won't open?
    If anyone can help me or point me in the right direction to sort these niggles out I'd really appreciate it!
    Thanks,
    Daniel.
    Oct 2009
    Hull
    1,442
    Re: A few issues...
    Check the drain plugs under the battery and brake servo
    The light in the boot and it not unlocking will be the same thing probably a broken wire between the hinge and boot lid
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Welcome to the forum. Have a look in the DIY guide's sticky thread as the majority of those issue's have guides to help you.
    The driver's footwell might be a leaking ECU box seal if it isn't blocked drain holes.
    Glovebox catch's are a weak point, that's covered in there too I think.
    Oct 2009
    Hull
    1,442
    ooops didnt realise it was drivers side more then likely the ECU box but check both they are easy enough
    blocked drains are usually passenger side
  1. A few issues I could use some help with.
    By eightrac in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2009, 08:04
  2. few issues... draining battery, lumpy idleand sounds like a tractor
    By hannakournikova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2008, 10:27
  3. Just bought an A3 and have a few issues - can u help??
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2008, 19:56
  4. A few issues
    By Rev-head in forum Diesel forum
    Last Post: 7th March 2006, 21:17
  5. Just had 1.8T Sport chipped... few issues?
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2004, 10:42
