AH FabricationsEM Tuning
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By VagCabby
Thread: The 'Econ' button...
    Dec 2012
    Northants
    217
    Would I be right in thinking that aslong as the light on this button is 'on' the aircon is 'off'???
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    224
    Quote Originally Posted by Dogtown22 View Post
    When the light is on then aircon is switched off economy mode
    pbarlow0032 likes this.
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
    Mar 2009
    470
    As already said, yes you would be right.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Sep 2009
    Rumburgh Suffolk
    188
    And if the temp is below 5 deg C, the electric PTC heater will not cut in either, so the interior will take longer to warm up.
    Not sure what the heater is rated at but it pulls a fair amount of current..
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Dec 2012
    Northants
    217
    Cool (excuse the pun ) thanks guys
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,754
    regarding the econ button....
    dont use it!
    just use the normal climate control as the clutch on the air con is prone to failing and then your just left with econ only as it wont turn off!
    Sep 2009
    Rumburgh Suffolk
    188
    Regarding the PTC heater, I believe these are only fitted to the derv burners..
    Not sure what the difference is anyway if left on? mines always on..
    Mark
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    637
    Excuse my ignorance... a PTC heater?
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Apr 2012
    202
    Quote Originally Posted by benjie View Post
    PTC heater is an electronic heater in the heater box, most commonly fitted to new diesels as a diesel engine takes longer to warm up compared to a petrol due to it's thermal efficiency.
    As for the ECON but it doesn't totally turn off the AC compressor as the compressors don't have a clutch like older AC compressors there constantly driven all the ECON button does it reduce the compressors working load down to about 5-10% as modern AC systems are designed to constantly run to keep the oil in the system moving and lubricating the seals and moving parts to reduce leakage of the system and keep it within EU limits of 4 grams of gas a year.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,754
    ok then! so, out of curiosity then, when somebodies econ button is permanently on and wont turn off, what is at fault or normally at fault in that instance?
    Oct 2009
    Hull
    1,440
    Re: The 'Econ' button...
    It could be a number of things
    No or low gas faulty sensor etc
    If the econ light won't go off get it scanned first
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,754
    ok will bare that in mind!
    mine is ok by the way, i was awlays under the impression from reading posts on here never to use it and just stick to using the auto climate settings! which i do! just in case!
    Oct 2009
    Hull
    1,440
    Ah thought you was having problems!
    I always leave mine on auto its so efficient you don't notice any gain having it off!
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by demus View Post
    it has a 30amp fuse!
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Apr 2012
    202
    Quote Originally Posted by CHEZ View Post
    As Stu_M said it's most likely to be low gas level - leak somewhere probably condenser stone damage. But only way to be sure would be to get the codes read and also pressures in the system checked with an air con service machine hooked up.
    The old style clutch compressors went out with the B5 model I think and the older a3's due to the EU laws changing. Manufactures had to rework how the systems worked to keep the system constantly pumping the gas around and carrying the lubricating oils with it to stop systems getting leaks at the joins.
    I only know all this as I work for VW and recently did the training course on AC/Climate control systems and we went through all the differences.
  1. econ button
    By williams in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st March 2011, 11:15
  2. ECON BUTTON
    By markA4tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2010, 11:53
  3. ECON BUTTON
    By Sm3g in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2009, 14:33
  4. Econ Button
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd May 2009, 15:28
  5. What does the 'Econ' button do?
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2004, 13:23
