Results 1 to 9 of 9
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Interior light control unit location and wire colours needed
    Hi all I'm wanting to know where to find the source of the power for the interior lights that come on when unlocking the car, I'm guessing there its a control unit or ccm somewhere, dose anyone know where its hidden in my 2003 3.0V6 Avant and if anyone can tell me the pin location and wire colours that would be awesome.
    Oct 2009
    Hull
    1,440
    under the carpet under the passenger front seat there is a central convenience module not sure what pin it is though!!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    its the CCM under the pass seat
    bez101's Avatar
    Jul 2008
    8,472
    what proble are you haveing ?
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    No problems,
    I want the interior light wiring as I'm using the switched power source for the interior light to activate another circuit through a relay to switch my LED fog/drl's on when unlocking the car, it will be wired in such a way that there will be no back feed issues when the car is running.
    Oct 2009
    Hull
    1,440
    hmmm very good idea that
    would be good to do a write up too :-)
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,265
    these are the colors of the wires which i used to fit footwell lights as i wanted them to come on with the interior light. I can only assume that you need to find these at the control module under the passenger carpet.
    Footwell Lights "ON" with Interior light:
    Based on the Interior Light connector and if you want the footwell lights to come on with the interior light then use Pin 3 (red/yellow) and Pin 10 (red/white) - these connections are effectively across the Interior light bulbs of the roof light, so run these wires to all your footwell lights in parallel.
    (Note: I have not tested this - but have looked at the circuit diagrams and this should work - also note you may want to fuse the feed to the footwell lights with an in-line fuse connection for added safety.)
    The guy who seems to know these car electrics inside out is called woorlord, im not sure he is on as much anymore but would be worth a pm
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Thanks for that
    Sep 2009
    Rumburgh Suffolk
    188
    Quote Originally Posted by dpbayly View Post
    No problems,
    Can't that be coded in with VagCom???
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
  1. Replies: 0
    Last Post: 29th November 2012, 21:07
  2. JVC HU Install and wiring help needed!
    By stephanbegley in forum In-Car Entertainment
    Last Post: 17th October 2012, 15:05
  3. Replies: 0
    Last Post: 30th December 2010, 12:50
  4. Airbag control unit location anyone
    By NHN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2008, 20:22
