Thread: Various Issuues
    Dec 2012
    Johannesburg, Republic of Southern Africa
    Angry Various Issuues
    Dear Friends
    I have an Audi A4 2003 2.5 TDI Quattro Techtronic (Auto). Bought second hand six moth's ago. I recently drove the car to the filling station with an intention to fill up fuel (Diesel), the car showed a zero mil on the tank, the distance was less than a kilometre. When I got to the filling station my car just stopped idling, that was it, it would not start. Now been parked for three days. I have replaced all the valves (incl. silenoid compressor) and the 8 mm tube for ther air pipe, the vacuum pipe, glow plug relay, pollen filter, new brake disks and brake pads. The ABS and ESP light went on, the glow plug light and start foot step warning light does not switch on,
    There is no fuel supply from the tank to the diesel filter. The tank fuel pump is not receiving power
    Mileage 177000km
    Please help with some advise, before I consider the Audi service centre
    Thank you
    Sakonta
    347
    347's Avatar
    Sep 2006
    253
    your in the A3 section here buddy , but it sounds like your fuel system needs bleeding .
    sugest changing fuel filer , and filling the filter housing with fresh fuel then try again.
    perhaps a moderator will move this to th relevant A4 section
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,446
    Quote Originally Posted by 347 View Post
    Thread moved to the correct section. x
    Jun 2012
    Teesside
    448
    I know its not exactly the same car or engine, but i had a mk4 golf gttdi, which did the same, i pulled it outside my house went to start following day and it turned but wouldnt fire, i changed the tandem fuel pump. injector loom, and it ended up being a burnt out relay and a section of the wiring loom burnt out, never did find out how it happened, hope this helps
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Dec 2012
    Thank you so much 347, I shall try it, much appreciated
  1. various issues...
    By Sayre in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2007, 21:35
  2. various
    By Alans in forum Classic Audi Forum
    Last Post: 16th May 2006, 19:06
  3. Various videos of mine
    By scoTTy in forum General Chat
    Last Post: 15th January 2006, 19:58
  4. Various "Races" and competions using company cars
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2005, 17:58
  5. pics of various wheels on a b5
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2005, 10:25
