Monster MotorsportChris Nott
Results 1 to 20 of 20
    Dec 2012
    Northants
    217
    Fitting a sony head unit in a factory A$
    Looking change the Audi chorus tape deck in my A4 for a sony headunit I've got, I've ordered the facia and removal tools so far, is there anything else I will need???
    Jul 2011
    Cornwall
    205
    A length of wire and a Scotlock to wire in a switched live from the fusebox.
    Oct 2009
    Hull
    1,433
    and one of these to power your aerial amp
    12V Amplified Car Aerial Booster Adapter FM, AM Antenna | eBay
    make sure it has the right connectors though as this is just an example
    Dec 2012
    Northants
    217
    Well I tried it today but with no joy.
    After I took the chourus out I fitted the plugs (2 out of the 3 as I'm guessing one is for multichanger)to my sony and nothing. I then swapped the red and yellow wires round (I'd read somewhere that you need to do this) then the sony untit sounded like it does when its ejecting a disk but then nothing again. I didnt try switching it on with the engine running, I just had the ignition on.
    Any Ideas????
    Jul 2011
    Cornwall
    205
    Have you wired in the switched live from the fusebox? I sound like you haven't.
    One feed is permanent live (goes into the +12v)
    The other one is switched live, Audi's don't have them so you have to wire that up yourself.
    Do a search on here as there are numerous posts with numerous people attempting to install aftermarket car stereos to Audi's without researching before they commit to the install.
    Dec 2012
    Northants
    217
    Ahh I see, no I didnt, I just thought that would be so your stations/settings didnt reset, I never realised that would be needed to turn i on. The only reason I'm changing it is because the buttons on my chorus are all worn and I looks abit shabby, looked at buying another off flebay but to my amazement they're £150!
    Oct 2009
    Hull
    1,433
    If you dont put a switched live on you need to send power down the memory circuit and the switched live circuit on the head unit wiring and turn it on and off manually
    there is a thin wire that runs to the ignition that is switched live and stays on till you remove the key you would need to run a feed from that to a relay and feed the relay from the fuse box or battery...fuse box is easier then battery
    Dec 2012
    Northants
    217
    Hmm think I'll stick to the factory unit!
    Oct 2009
    Hull
    1,433
    Its really easy to do and well worth it your almost there already!
    Dec 2012
    Northants
    217
    So would I need to buy a relay stu??
    Oct 2009
    Hull
    1,433
    yes just a standard 4 pin relay will do an inline fuse too
    if you dont know how to wire a relay heres a pic
    Dec 2012
    Northants
    217
    Many thanks stu. Could I not just splice a wire into this switched live and into the red wire that comes out the back of my headuint??
    Oct 2009
    Hull
    1,433
    No the switched live from the ignition is only a really thin wire and cant handle the current for the radio it will overheat/melt and pose a fire risk
    there is other switched lives on the fuse box where you can take a feed from straight to the head unit but will just go straight off with the ignition and not stay on with the key in like OE...I dont know what feed you would need for this though
    Jul 2011
    Cornwall
    205
    Yes you can do it that way, doing it this way means that when you switch off your ignition, after a few seconds your head unit will switch off.
    Using a relay means the head unit will switch off when you pull your key out, just like your factory head unit.
    It would sound like option 1 would be easier for you seeing as you're almost there already.
    Dec 2012
    Northants
    217
    Quote Originally Posted by stu_m View Post
    Right mate, well a fire risk is a no no, hopefully someone will be along to say about another switched live, I'm not fussed if the stereo only turns on with the ignition on, I'm old skool!
    Oct 2009
    Hull
    1,433
    Have you not got a multimeter? if not pop to halfords and buy one they are only cheap and worth their weight in gold
    then have a poke around and you will soon find a switched live
    Dec 2012
    Northants
    217
    Dont own on Stu but there is one at work, will have a poke about!
    Jul 2011
    Cornwall
    205
    Quote Originally Posted by Dogtown22 View Post
    Sorry, I should've made myself clear with my post, I was referring to the switched live cable from the fusebox, not the ignition.
    I can't remember of the top of my head which feed I tapped into. Use a 12v tester or multimeter to find it, it's not hard to find.
    Jan 2012
    1,599
    Any Ideas????
    Ok the unit is getting power - press the power button on the stereo and see what happens.
    Dec 2012
    Northants
    217
    Quote Originally Posted by A6CR View Post
    Yes did that.
  1. Help fitting my Sony head unit to my Audi A3
    By Twigger245 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 11:00
  2. Fitting an aftermarket Sony Head unit!
    By iggy2202 in forum In-Car Entertainment
    Last Post: 9th January 2007, 23:39
  3. A guide needed what to do with Fitting a Alpine Head unit in my A4
    By Rev-head in forum In-Car Entertainment
    Last Post: 3rd September 2006, 00:06
  4. Sony Head Unit Problem
    By andy64 in forum In-Car Entertainment
    Last Post: 25th February 2006, 15:18
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
