Chris NottVolks Autos
Results 1 to 7 of 7
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    OEM Xenon lights poor
    My stock hid headlights don't seem to be any more effective at lighting the road ahead than halogens, in fact when the main beam or foglights are on the xenons light is almost lost, yet when I see the growing number of other cars on the road with xenons they're almost blindingly bright. I've fitted new oem Philips lamps but the difference is negligable. The light throw is good they're just not that bright. Side by side with anything new with hid's and it's almost embarrasing. Is any body else of the same opinion that the stock lights are poor or any advice on what to check with mine, cheers.
    Nov 2006
    cardiff
    88
    same with mine i put new d1s bulbs in and still rubbish, my m3 xenons are much better
    JasonS's Avatar
    Feb 2012
    North Herts
    86
    I sometimes wonder if mine are on at all.. the only good thing about them is the self levelling.
    I had a vauxhall Omega Elite in 1998 that had fantastic factory xenons, nothing has come close since.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    Looks like I'm going to have to start modding then .
    I think the self leveling is good too,especially on start up,but occasionally in fog /snow I'd prefer to be able to manually drop them.
    2004 A4 Sport Cabriolet 3.0
    Oct 2012
    385
    at least i am not alone in my thoughts, i am disappointed with mine, just seem to fall short in terms of output, coverage and range, i rememner fitting an hid to kit to an old urs6 that i had and being blown away by the difference, had elipsoid headlights so wasn't chav / corsa look at all, glass lenses though not plastic, hmmmmmm
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    65
    I decided to have a closer look at the lights today, with the intention of cleaning the internals of the projectors and this is what I found. You can see the projector has overheated to the point of cracking and the reflective surface is now charred and black. Both driver and passenger lights are like this. My car has the factory fitted xenons and hasn't had high power lamps fitted,just genuine replacement lamps (philips 85122) . I'm quite surprised that the reflectors are plastic as I would have assumed that xenons run quite hot. If your lights seem dim maybe pop the lamp cover off to see if yours are the same. It doesn't look like the reflectors would be available seperately, anybody any idea how costly new headlights are?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    I'm sure OEM replacements are going to be extortionate.
    Maybe you could buy non Hid type and convert them using the factory parts from the old headlight ?
  1. Xenon lights? Get flashed at?
    By slimbloke in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2004, 00:33
  2. any adjustment on S3 xenon lights?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2004, 09:24
  3. Cheap xenon lights on ebay
    By Mattgurnett in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:35
  4. xenon lights fogging up
    By ultrasporta4vk05 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2004, 15:55
  5. Xenon lights
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2003, 17:04
