Chris NottSky Insurance
Results 1 to 29 of 29
    Dec 2010
    6
    Key fob will not lock or unlock
    A4 Cabriolet, B6, 52 reg.
    The other day my fob stoped locking or unlocking the car, now i have to open with the key.
    The central locking works from the buttons on the door once in the car and the lights blink when locking / unlocking with the key.
    I have had the fob checked for a signal and was told it is ok.
    I tried to rematch the key to the car following the methods on the forum but no change.
    Any other ideas of what could be causing the problem, Cheers.
    Southampton
    158
    Tried replacing the battery? Low battery could be strong enough for a signal but not enough power to activate central lacking?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    I tested an option in VCDS that when you set the car to Transport Mode, it disabled the remote locking, along with 1 or 2 other things. Exit Transport Mode returned it to normal. You haven't had it on VAGcom recently have you?
    2009 A3 SB 2.0T DSG S line
    Oct 2009
    Hull
    1,433
    lock the car and leave it until the hazard light goes out
    then press unlock on the fob if the hazard lights up it is getting the signal but not unlocking the doors
    mine did this and I had to disconnect the battery for a few minutes then reconnect and all was well
    Dec 2012
    West Yorkshire
    10
    Hi i had same problem with my fsi lights flashing but no sound . i put spare key in ignition. other in door pressed open 4 times . then again. works fine now.
    Sep 2006
    27
    Mines intermittent. Ocassionally doesnt work. Fuses? Not sure whether central locking is fused?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    mine miss fired once last week! hasn't done it since and I pit it down to either a lowish car battery (now charged) or the receiver didn't pick up the signal.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Just put key in ignition turn on (dont start) press lock and open button and all should be good if the battery is not dead.
    Sep 2009
    Rumburgh Suffolk
    175
    Mine has done this a couple of times, tried all the usual things of holding lock / unlock, in door, in the ignition etc... nothing worked.
    For some reason the car loses the code and it all needs re-coding, Audi charge about £40 to re-program it....
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Oct 2012
    Stanley, County Durham
    148
    I've got the same problem with my spare, Demus can you just get this done at any Audi main dealer? I keep putting off sorting this, but I need to do it before I need it!
    Sep 2009
    Rumburgh Suffolk
    175
    Quote Originally Posted by pbarlow0032 View Post
    I'm guessing you can yes, I'm not sure if the buttons on my key are anything to do with it, it used to work from a hell of a distance, now you have to be in spitting distance.. batteries all ok.. It seems to do it if when walking to the car, I press unlock, it doesn't unlock due to the crap range, then press a couple of times more, it all gets out of sync and goes tits up.
    I only have the one key and keep telling myself I really should get a spare, still haven't got one!!
    Only takes about half an hour for the stealer to do.. if anything like mine they will also tell you that there are numerous fault codes stored, they have obviously read them, but won't tell me without another wad of cash, twats...
    Got VCDS and no codes were stored !! (Oh, and that it was allegedly running rough ??)
    Anyway rant over, check on here, there are some clever guys with the full VCDS and could probably do it for you cheaper than the stealer, sorry I mean main dealer...
    Mark
    Oct 2009
    Hull
    1,433
    you dont need it recoding at the dealer it will more then likely be the fob thats working loose and loosing contact with the battery
    Open the fob and bend the battery pins out slightly loads of us had the same problems on here and did this and all has been fine since
    do a search
    Sep 2009
    Rumburgh Suffolk
    175
    That didn't work with my bugger unfortunately... I did wonder if the antenna in the car was ok, don't suppose anyone knows where it is ??
    Mark
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    The receiver is by the centre speaker on the dash, where the flashing red LED resides
    Inertiauk's Avatar
    Mar 2011
    529
    Quote Originally Posted by demus View Post
    audi have been pulling your pants down its really easy to do you just need 2 keys (1 doesn't have to be a remote key)
    1) Take the key you DO NOT want to program and put it in the ignition. Turn it one click forward.
    2) Close and lock the drivers door with the second key.
    3) On the second key (the one in the drivers door) press the 'UNLOCK' button ONCE only. The lights will flash on the car, but the doors will remain locked
    4) With the second key still in the drivers door, unlock then lock the door again.
    5) Pull the key from the slot and test remote functions.
    6) Open drivers door, remove key from ignition.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    Sep 2009
    Rumburgh Suffolk
    175
    [QUOTE=Inertiauk;1748459]audi have been pulling your pants down its really easy to do you just need 2 keys (1 doesn't have to be a remote key)
    Doesn't suprise me in the slightest, after all the crap about fault codes which didn't exist..
    Thats persuaded me to get another key.. can that be programmed the same way as you said above??
    Mark
    Jun 2011
    Great Melton Norfolk
    1,340
    you will need SKC to code new key to car with vcds , you may have it on small tab with your handbook/key.
    Inertiauk's Avatar
    Mar 2011
    529
    Quote Originally Posted by Inertiauk View Post
    the second key needs to be coded to the cars immobiliser system which does need to be done by a specialist. However there is a way around it if you don't have a second key.
    get a plain key and have the blade cut, sit in the drivers seat with the window down and the 'cut but not immobiliser programmed' key in the door outside.
    Put your original key in the ignition and turn to position 1.
    either have a friend help or reach our through the open window and lock the car using the 'cut but not immobiliser programmed' key.
    press unlock, lock, unlock on your original key, then remove it from the ignition. Remove the key from the door and test your fob, it should be working.
    Hope this helps.
    Oct 2012
    148
    My spare key doesn't work as a remote but does open and lock the car in the door lock, and does start the car. I put a new battery in the spare key when I bought the car (a few months ago). Should the process InertiaUK mentions above work? I might have another fiddle with the battery pins (cheers STU_m).
    Oct 2012
    148
    Right, tried pulling the pins out a bit, battery is definitely making contact. Tried battery both ways up too just in case. Nothing at all happens when I press the unlock/lock button. No lights flashing etc, no locks unlocking! If I read the earlier posts correctly, it should still make the alarm lights blink evn if it isn't opening properly?
    Oct 2009
    Hull
    1,433
    Re: Key fob will not lock or unlock
    You did sync it first?
    Inertiauk's Avatar
    Mar 2011
    529
    You have 2 keys for the car, sync it as in the first post I made above .
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    I've had the same problem twice now, without knowing the exact reason it stops working, in my situation, its been related to the antenna / receiver for the fob.
    If you go into the boot, and simply try pressing the key fob in a few random places, hopefully, it will receive the signal and all will be well again - mine just works as per norm now
    A4 Avant 1.8T (190) Sport
    Oct 2012
    148
    Inertia, I tried doing exactly what you describe in your first post, but when I press the unlock button on the (non working) key, there is no light flash. Am I missing something obvious?
    Lancaster
    1,637
    I recently had this. Took the car battery off, put it back on. All good.
    To do: None yet.
    glenandem's Avatar
    Sep 2012
    manchester
    457
    same here with my spare key,tried new batts and all different ways of coding and never get flashing lights?
  28. #27
    Stu!!!'s Avatar
    Feb 2011
    Cardiff
    60
    The booster / Antenna for the fob / signal is in the boot, if you move the fob around the boot whilst pressing either lock or unlock etc, it will pick up a signal again.
    This has worked everytime... resyncing, disconnecting battery etc just didnt work ...
  29. #28
    Oct 2009
    Hull
    1,433
    Quote Originally Posted by Stu!!! View Post
    Could peoples problem be broken wires between the boot and main body?
  30. #29
    Dec 2012
    West Yorkshire
    10
    Hi thats a strange one if it works in the boot but not outside the car could be a reciever problem, like i said earlier mines just stopped working both fobs..lights where flashing no sound i got in car turned ignition on and it stopped..i checked the forums and it just said open drivers window, put one ket in ignition turn but dont start other key in door press open 4 times lights should flash, then do it again and that should be it..i had to use key when it went on one i was like wtf....but its fine now both keys work
    can you not get someone with vag-com in your area to check for error codes
  1. unlock button on key fob not working after reconecting car battery
    By jonnyb289 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2012, 08:56
  2. Key Fob problem - Not locking or unlocking
    By a3tazza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2012, 01:16
  3. Drivers door lock will not unlock with key - HELP
    By graves_x in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2012, 23:39
  4. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  5. Key fob not working
    By S3-James in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 19:15
