Results 1 to 8 of 8
    AudidriverA4's Avatar
    Sep 2012
    179
    Play / Rock in Drivers Seat
    Evening all,
    My A4 has a slight rock or 'give' in the drivers seat, which I find is quite annoying as it can be hard to get comfortable sometimes and the seat can sometimes make a noise going over rough roads etc.
    They are the SE seats
    I know its hard to diagnoise a problem over the internet but could it possible be a loose bolt/nut holding down the seat?
    Is there anywhere else to look for a loose bolt/Nut ?
    Anyone else come across a problem like this before in an A4?
    Also the seat also does not slide that far up and down i.e the passenger seat slides back further and forward than the drivers seat maybe that has that something to do with it ??
    AudidriverA4
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    does it have the electric lumber support option ?
    Jul 2007
    765
    could be something jammed in the runners
    Sep 2012
    179
    Quote Originally Posted by Turkster View Post
    No doesn't have electric lumber support
    Quote Originally Posted by Mike B View Post
    yeah I checked the rails this evening and found a thick screw lodged in the rails so that sorted why the seat wasn't sliding up and down fully.
    As for the Seat itself I reckon its just worn out,
    I'm have thinking of now fitting a set of B7 Sport seats into it.
    Oct 2012
    30
    Mine do this in my Avant
    Oct 2009
    Hull
    1,433
    mine rock a little
    I'm sure I have seen on here that its the rivets that hold the seat to the slide and the only way to sort it is to weld them!
    Sep 2012
    179
    I usually drive with the radio turned up a good bit, but if I drive with the radio off, there is a good bit of noise coming off the seat, it sounds like springs squeaking aswell as rocking .
    Welding the seat actually sounds like a good idea, but I'm not the best at welding light materials
    I think changing the seats might be the best option in my case
    Just going off topic now but SE vs Sport seats would be the most comfortable ?
    Mar 2008
    1,016
    couldnt you drill out the rivets and nut and bolt them ... or wouldnt there be room for bolt heads ????
  1. S3 Driver seat problems
    By RS-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2006, 20:43
  2. Creaky drivers seat
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2006, 23:19
  3. Drivers seat wiring loom
    By Bongo163 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2006, 17:12
  4. Drivers seat problem...
    By JoeInIreland in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2005, 16:19
  5. My Drivers seat has the wobbles
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2004, 16:26
